Question about Homelite Mighty Lite Lawn Trimmer
Starter on trimmer wont retract
Homelite Mighty Lite trimmer. Went to start it and when I pulled the started handle, it stayed out and the started cord did not recoil. Can I take off the cover to loosen tension to let it recoil? Any help would be great. Thanks!
  • 181 Answers
I'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Posted on Jun 02, 2009
SOURCE:
When I pull the starting cord it does not turn the motor to start
Disassembly will be rquired to diagnose and/or repair the starter recoil unit. This is a common problem that is caused by a less than stellar design/poor engineering and normal wear and tear. The manufacturer like to use a lot of plastic in the parts and they don't wear very well.
Jan 16, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite UT21947 Mighty Lite and the stater pull is stuck. It will not retract.
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Sep 22, 2010 | Homelite Mighty Lite Lawn Trimmer
Gentlemen, I have a Mighty lite Trimmer of which the cord does not recoil. It appeares that the heavy torsion spring bends when cord is pulled and cord stays out instead of recoiling. Where can I get...
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Aug 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Hello, my mighty lite 26 ss weed waker is broken. The starter cord will not retract. it stays out and I am unable to start the engine. what is the problem and how do i fix it? thank you
You will have to disassemble the unit to that point and inspect the recoil pulley (rope coils on it) and the ratchet mechanism under it and the recoil spring that draws the rope back in.
Aug 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Can not get it started.
have you tried to replace the H T lead?
Jul 22, 2010 | Homelite Mighty Lite Lawn Trimmer
Pull cord stays out. Mechanic says I need new
check with home depot on parts for a homelite.
Oct 21, 2009 | Homelite Mighty Lite Lawn Trimmer
After turning of engine. Starter pull cord stuck.
The recoil spring that rewinds the cord may have broken of pulled loose from its mooring.
Sep 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Hard to start and keep running
By "pulley assembly" I assume you're talking about the recoil on the starter cord. You can check E-Bay. I just did. There was one for $15.00. But I don't know if it'll fit your model. PLEASE rate my answer.
Sep 04, 2009 | Homelite Mighty Lite Lawn Trimmer
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
I cant start it due to the pull cord not coming out further than 5-6 inches??
Sounds like the cord may be wrapped outside of the recoil pulley and may be spinning the motor backwards. The cord can backlash especially if the trimmer kicked a bit during starting.
Apr 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
874 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
