Question about Zephyr Savona ZSV-E30AS Stainless Steel Kitchen Hood
Fan doesn't work on the two lower speeds. Makes noises on high.
This Zephyr Savona hood range was wonderful until two weeks ago. The fan on low speed started making noise and then it and the medium speed fan have quit. Also, can you tell me how to get to the switch to change it, if it is the problem, and where can I can a new switch.
3 Suggested Answers
SOURCE: Zephyr Savona Range Hood only speed 3 works
had same problem (w/in a few months)
switch assembly poor design
thay sent a replacement (i put it in)
seen other complants
Posted on Jul 20, 2008
dniro592006
  • 121 Answers
SOURCE: Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
Posted on Jun 02, 2009
May 27, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Feb 08, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Feb 06, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Jan 12, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Dec 12, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Jul 15, 2008 | Kitchen Ranges
Noisy fan
MOTOR HOUSING IS CRACKED MADE OF PLASTIC
Nov 26, 2006 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Flap valve and noise
The flapper valve is a weather valve. Usually, it is installed in such a way that the flapper is vertical and closed. The pipe is installed on the horizontal...you'll need an EL pipe. Pivots allow it to open when the fan is on. If you don't install it, wind will blow into the unit and you will be rather unhappy.
It is possible that the sound you hear is normal when opened up. With all the covers in place, it should be nearly silent.
http://www.zephyronline.com
Oct 10, 2006 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona ZSV-E30AS Stainless Steel Kitchen Hood Logo
53 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
