Question about E-Machines (T2958) PC Desktop
Video controller i need help figuring out how to make my resolution better i cant get it to go past 640 to 480 setting and have tried almost everything i go to device manager and it says video controller vga compatible
    President:
  • 948 Answers
You are using the built-in video driver provided by Windows. You need the video driver from E-Machines. You can download that here.
Posted on Jun 02, 2009
Cant get a full screen
You may need to change the screen resolution.
Go to Control Panel - Display - Settings tab - in Screen resolution, move the slider to 1024 x 768 and Apply.
If you cannot increase the screen resolution then most likely the incorrect video driver has been installed. Install the correct video driver and you will be able to increase the screen resolution.
Apr 02, 2012 | Computers & Internet
When connecting to tv playstation says mode not supported
Whatever resolution your PS3 is outputting isn't supported by your television. Figure out what resolutions it can handle (it'll be 480p, 720p, something like that; probably written on the TV itself, definitely in the TV's user manual). Navigate to your console's display settings. It should be Settings > Display Settings. Select the Video Output Settings, choose your connection type (which wire you're using to connect to the TV), and then select the resolutions your television can handle.
Sony has a much better guide to doing this, with pictures! (everyone loves pictures)
Hope this was helpful!
Sep 02, 2011 | Sony Playstation 3 (PS3) Console
Using Windows XP with a terrible, terrible video card. Will not go above 640x480 resolution. Only has 8mb video ram and Windows won't let me raise past that. Was wondering if there was any way to force...
if windows does not have the correct driver for the graphics card the resolution may be stuck at a "safe" setting, try downloading and installing a graphics driver, if the graphics card is very old and its maximum resolution actually is 640x480 there is no way other than replacing the card to achieve a higher resolution
Jul 25, 2011 | Computers & Internet
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Frequency out of range
First of all press F8 key several times before window boots and then select last known good configuration otherwise go in safemode and then set the screen resolution to minimum.
Jul 28, 2010 | Gateway 838GM (RB838GM) PC Desktop
Can not config the size
if the screen is big, try to change the screen resolution, or install the video driver from the manufacturer drivers disk that you would have,,,
refer to help and support in your computer for guidance on how to reduce the screen resolution,,,
click on start >>>> help and support, then on the search box type how to change the screen resolution
2. how to install the video driver
you will have step by step instructions, and you could get it resolved,
follow those steps clearly
Feb 14, 2009 | Acer AL1912 19" LCD Monitor
I want to view half screen, not full screen
Go to the video settings and change the resolution.
Aug 25, 2017 | Computers & Internet
Setting correct screen resolution for external monitor
Instead of looking to the laptop drivers, try looking for the monitor drivers. If there aren't any, then research the video card for the machine to see if the specs you have are wrong. If there aren't any drivers for the monitor, then the drivers at Toshiba's support site should work, since they don't, I'm going to say it's in the video card.
Aug 20, 2008 | Toshiba TE2100 Notebook
No video signal
• The resolutions available for HDMI output depend on the connected TV or projector. For
details, see the user’s manual of your TV or projector.
• When the resolution is changed during playback, it may take a few seconds for a normal
image to appear.
• If you set the HDMI output resolution 720p or 1080i, HDMI output provides better picture
quality.
• If 720P or 1080i is selected, C-VIDEO, S-VIDEO and component video will not ouput video
signal. Press and hold the SUBWOOFER button on the front panel to reset the HDMI
Resolution setting.
Oct 06, 2007 | RCA RTD258 System
E-Machines (T2958) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
