Question about RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
My RCA Bigscreen HDTV (Model #: D52W19) used to blink and then just shut off on its own and I couldn't turn it back on. I would have to wait an hour or two before trying and then it would come on. Today this same TV went dark and made a "fizz-fizz" sound and then shut off. I pushed the power button, the TV came on (only got a black screen), it immediately made the "fizz-fizz" sound and then shut off again. Turned on the TV this AM with the remote and nothing happened. Tried the front panel switch, the green light came on for a few seconds went off, then back on and off for three tries, then stayed off. Check plug. TV was working well when wife turned it off last night.
    Scholar:
  • 62 Answers
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 04, 2009
  • Vincent Oct 16, 2010
    I also have the same problem with the RCA D52W19. The capacitor rated 2200/16 is bulged both ends but my problem is finding a replacement. The closest I have is 1000/16, but I'm not sure that would be wise to replace with? What do you think?
I just ordered the same capacitor off of amazon for just over $3 for 3
Posted on Apr 05, 2013
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Working fine, then shut off.. won't come on, no power
A clogged air vent will cause the unit to overheat and not turn on.
Apr 16, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 b
I had the same problem and found it was the cp150 which is in the back left circuit board. Cost me $2. Easy to change.
Feb 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
1,000 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
