Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Craftman mower will not start
The mower will not keep running, replaced fuel, filter and plug the primer gets only enough to run for short while
  • 34 Answers
If you can or know someone that can do it, take off the carb. and soke it in some gas for a couple of days. Also check to see if your primer has a pin whole in it.
Posted on Jun 02, 2009
  • 10,865 Answers
Hi there. I can help you. The problem is that your carbeurator is gummed up. You may have to remove the carb. and soak it in carb. cleaner for a few hours to get rid of the gum. However, I have often had luck with a fuel additive called seafoam and a carb. cleaner spray plus some starting fluid. Put the seafoam in your fuel using one ounce per gallon, then remove your air filter and squirt carb. cleaner in the air intake, two five second blasts. Try to start the mower. If it starts, great, if not let it sit for an hour while the carb. cleaner dissolves some of the gum. Try again ain an hour using more carb. cleaner and some starting fluid, a couple of blasts of each.
I have the Craftsman GT5000 24 OHV tractor lawn mower. It's been in storage for a while, I have replaced the battery, spark plugs, fuel filter, and oil. I can't get it to start. Does the engine have a pump...
Sounds like the carburetor needs a good ultrasonic cleaning as old gas will leave behind varnish and gum deposits clogging the carburetor fuel passages up.
Mar 29, 2015 | Craftsman Garden
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 1438766000 Mower, carburetor problems,... Mower will start using either and will run as long as I am pumping gas in with a spray can,... took out and cleaned the carb, replaced the 2 small O...
I had this problem with my Rover Mower a while ago. It nearly drove me mad trying to figure it out. And then I did the only thing I hadn't done so far. I cleaned out the fuel tank. And sure enough, there was a fair amount of gunk in it. And I also cleaned out the filters while I was going...no problems ever since
Apr 08, 2011 | Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
I have a craftman 17 hp riding mower. It will start and run but Then it will die like it isnt getting gas. Replaced the fuel filter and spark plug.i can let it idle for a few minutes and it seems fine. I...
Remove the bottom bowl of the carberator and replace the needle-valve and float - cleaning this area as you do so.  Sounds like the float has a hole in it or the needle valve in the carb is sticking.  Use some fuel stabilizer prior to storing for winter next time, if not the old gas turns to shellac and makes things stick.
Jun 12, 2010 | Garden
Saw is a 14 inch model 1950. Saw starts but won't run
Check the fuel filter, air filter and muffler for plugging. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel after several pumps? Hope this helps!
May 12, 2010 | Poulan 14" Chainsaw
I have a murray 4hp that runs 15 sec per prime then stalls.
First. try using Carb Cleaner from spray can to clean carb throat, and putting Carb Cleaner in fuel tank.
If this does not work-
Removal of Carb is probably needed. Sounds like Carb is clogged and needs to be cleaned.
If this is a Briggs engine and the Carb sits on top of the fuel tank, can be that the pick up tube from tank to carb is clogged.
Jul 12, 2009 | Garden
Help with Craftman 5.o snowblower model @ 536885211
Turn on gas with the carb bowl off and float hanging and see how much fuel flows.It should be a steady stream.Have seen the seat in the needle and seat swell that only lets gas drip through not enough to keep it running.
Nov 21, 2008 | Sport & Outdoor - Others
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
256 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
