Question about ASUS CUV-NT (CUVNTWOTVWOV) Motherboard
Power Switch I cant get my motherborad to even start. I replaced an old motherboard with this one now i cant get it started. i think it may be my power switch because i had to replace it too. I dont know where and what order to place the wires for thre LED light and the power switch. I Know that everything is plugged in right, like the powersource and such, and i know the plug into the wall works because i just used it for something else, thats all i think the problem is, i just need to know who to fix it.
  • LordOfWar_89 Oct 24, 2007
    thanks for helping. i appreciate the help. i found out my problem, it was the CMOS pins. i had to jumper in the wrong configuration. Thanks!
  • 90 Answers
This board I think is an OEM board built by Asus for HP computers. Also named Pegasus.
Go here to find a PDF manual for that particular board -
On page 22, the last page, it shows you the pin-out for the connections for the front panel, ie - power button, reset, led's, etc. Hope this helps.
Posted on Oct 24, 2007
I would think its a mother board problem. it could also be a processor or ram problem, as its 8 years old i would think its lasted a good long time. there are meany reason for the motherboard to start to play up. they have smd capacitors inside and over time they wear out and start causing problems or regulator chips for voltage start to wear out. it could even be that its just old. you have done well to have one last 8 years. most you would get 3 to 5 years. so it was well made for its time.
Jul 01, 2017 | Sony VAIO VGN-NR385E Laptop
My pc stopped working - the power light is on but when i press the button to turn on the pc, nothing happens
power light runs off the main power source inside the computer. That part is working since the power light is on. The PC operates off the motherboard and other assocciated hardware on the motherboard which can be at fault it seems in your case.The hardrive should work and hear running when starting. If not your motherborad is at fault
Oct 02, 2011 | Computers & Internet
My pc starts up without pressing power button, cant switch it off with power button so iff i switch it off on the power supply and switch it back on it immediatly starts up not showing anything on screen...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
May 25, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Hi my dell inspiron 1520 not starting when power button is switched on..the power light blinks and goes off..and the system doesnt start. I had shown the laptop ito dell service center and they have...
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
But, if you paid for the Dell service, Dell needs to fix the problem. Sounds like they replaced the motherboard with another faulty one.
Hope this helps.
Feb 12, 2011 | Dell Inspiron 1520 Motherboard
Motherboard asrock is cant run
Depending upon what is your processor AND the OS you are using, The motherborad drivers are available at this link:
Go though it carefully and select the most compatible or appropriate for your system. Download and upgrade anything even its BIOS update,if any,................sodeep
Mar 19, 2009 | Asrock 775i65G Motherboard
Inspiron 1200 wont start
It sounds like defective video card or motherboard.
Dec 01, 2008 | Dell Inspiron 1200 Notebook
New Prossesor
I think that your MB does not support Athlon 1500. You can try with BIOS update.
Jul 10, 2008 | AMD Computers & Internet
198 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
