Question about LG Flatron L1710S 17" LCD Monitor
Computer monitor screen stays black
Ive recently had my computer monitor screen go black. i have turned it off and on again and i get the desktop to pop up for 2 seconds if that, then it turns black again. The menu button does not work, and I have tried my old monitor and it works fine. any suggestions Ive recently had my lg flatron 1915s computer monitor screen go black. i have turned it off and on again and i get the desktop to pop up for 2 seconds if that, then it turns black again. The menu button does not work, and I have tried my old monitor and it works fine. any suggestions
  • 822 Answers
Check secondary power supply budged capacitors and apply fresh solder. check also lamps connectors.
Posted on Jun 02, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
I have a very weird problem with my computer screen. When i start my computer it loads fine but after seeing my desktoop the screen turns black after 10 seconds. If i unplug and power supply of my screen...
what is the os u are using, mention ur operating system, it is just a screen saver problem, try it in properties by clicking left mouse button on the desktop, is there any error message on the desktop when u got black screen
Aug 07, 2013 | Computers & Internet
My monitor boots up with computer, but turns black when it gets to the desktop. if i turn the monitor off, then on again, it stays on for 2 seconds then turns black. can someone help me?
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2011 | ViewSonic VX2235wm LCD Monitor
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Backlight for display cuts out
Bad capacitors are a plague now, most likely cause of the black screen
simply remove the doomed and caps that have color leaking from the top. and replace with duplicate good caps from your local electronics store
Mar 22, 2009 | HP W2007 LCD Monitor
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
StudioWorks 700s Monitor No Signal
Try to connect the monitor to a different desktop/laptop, to see if it works at all.
Try a different monitor on your computer, to see if the video-card in your computer is the problem.
Or, spend $50 to $100 to buy a used 15-inch or 17-inch LCD monitor.
Sep 20, 2007 | Computers & Internet
LG Flatron L1710S 17" LCD Monitor Logo
755 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
