Question about Apple iPod nano
Screen locked up on ipod model A1137.
Screen just locked up in the middle of a song. tried the "menu + center button". resets and goes to the language selection screen, but can't move cursor up or down and the center button won't select. ipod is only 1gb, but it's just right for me. don't really have the money for a new one right now (i know, join the club) so, any help would be appreciated.
  • 144 Answers
Click menu and the circle button
Posted on Jun 06, 2009
SECURITY CODE MODEL NO A1137
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
Apr 29, 2010 | Audio Players & Recorders
How to restore my ipod a1137
hold down the middle button and the menu button until it resets.
Apr 06, 2010 | Apple iPod nano
I need to unlock my ipod nano
for one make sure the lock button on the top of the ipod is slid to the left to unlock the ipod's buttons.
The default code for the screen lock is 0000 and if you are still having problems then reset it. with the instructions below.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jun 22, 2009 | Apple iPod nano
Problem with IPod Nano Model A1137
Have you already reset the iPod? (Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.)
If this failed I would suggest going to: http://fixyouripod.weebly.com/
and view the free video's about resolving this kind of issue. If after that the issue is still not resolved, Please do let me know. :)
May 16, 2009 | Apple Audio Players & Recorders
How to get my language back to english
Select your language.
  7. Select your preferred language from the list.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Try holding the menu button and center button at the same time. this should reset the ipod completely. Its a force power up and power down similar to Zapping your PRAM on a computer. this should reset the configurations
Hopefully that helps
May 13, 2008 | Apple iPod nano
Apple Ipod a1137
you have to load 4 ours tehe first time.
maybe the battery is old , change it.
hold the menu AND the middle button pressed for 6 seconds
to RESET the ipod...
belly
Jan 19, 2008 | Apple iPod nano
Problem downloading videos on ipod model no. A1137 EMC no. 2066
which ear-phones,datacable & usb charger can be used for apple i-pod (model no.A1137)EMC NO. 2066
Jan 06, 2008 | Apple iPod nano
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Apple iPod nano Logo
436 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
