Question about Maytag Atlantis MAV7551 Top Load Washer
Drum doesn't lock when it aggitates
So when it aggitates the drum does not lock so it just spins and the clothes dont get clean
    Scholar:
  • 85 Answers
Your brake has malfunctioned. You will need a repairman to fix this. Sorry.
Posted on Jun 02, 2009
Candy1682d/180 will not spin with clothes in drum, empty drum and will spin what's the matter
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly, faulty pump, the timer or control board not communicating correctly.
Nov 02, 2012 | Frigidaire ATF6000ES Front Load Washer
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
I have an LG WM2277HS which will aggitate, but will not spin & rinse.
make sure the door safety switch is working correctly ,, if it doesn't show as locked, the machine won't spin
Jul 15, 2011 | LG WM-2277HW Front Load Washer
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
Maytag Quiet Plus 2 cloths washer - aggitator drain plugged up
Ok grab hold of the top of agitator about 4 inches from the top and just pull that top right off.Hit it at an angle and it will pop right off .Dont be shy ,its just plastic that is snapped onto plastic.To put it back on just line it up on top and Smack It back on.Easy Ha???Youll be able to clean it alot easier now.If you dont use fabric softener your problem will be gone for ever .Try using less and mix water in it first.I'll help you if you need further help..
Feb 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
Maytag Atlantis MAV7551 Top Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
