Question about Tomtom ONE GPS Receiver
Unit will not go past second screen - Tomtom ONE GPS Receiver
  • 38 Answers
I would try resetting your unit before calling tom tom to get it repaired.
view the following image
http://www.tomtom.com/lib/doc/one/refman/photos/oneBack.jpg
"I" is your reset button press and hold for 15 seconds or until the unit resets.
Posted on Oct 24, 2007
SOURCE:
LENOX MINI SPLIT HAS A F8 CODE ON THE SCREEN
Cycle the power to the outdoor unit. F8 is a low or high line voltage fault. Not likely a real error if the unit has worked in the past. Possible power surge or something.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 01, 2017 | Heating & Cooling
Invion 3v506 will not load
Try first unplugging all cables and let it rest for a while.
Keep the start button pressed for ten seconds.
I will check if there is an alternative way to reset your unit.
Sep 27, 2008 | GPS
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Dell inspiration 1520 doesn't go past Windows Error window. My computer goes past the dell loading screen, then Windows Error. After I pick one (or go into f8 and pick system repair) then the screen goes...
Possible hard drive failure. You may have to reinstall the operating system and if that doesn't work then you have to get a new hard drive. The tech may or may not be able to recover your files from the damaged unit.
May 18, 2014 | Computers & Internet
My nobis pc tablet wont get past the second loading screen
Do a hard reset. Hold the power button down for twenty seconds. This is a hard reset if this does not solve the problem I recommend returning it as this is more than likely a manufacturer issue
Jan 24, 2014 | Tablets & eReaders
How Do I Get Past a Pattern Lock MID8024
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Aug 23, 2012 | Coby Kyros MID80244G Tablet
I can't get past the opening screen. Tried the soft reset, holding switch for 10 seconds, both on and off. Can't get to screen for hard reset.
Base from the description of your problem, there;s no way we can perform a hard reset on the unit since there;s no reset button on this particular model, the problem here is a corrupted software and can only be resolve by taking this unit to a service center for repair.
Jul 04, 2010 | Magellan RoadMate 1340 GPS Receiver
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
MY TOMTOM XL 330-S WILL NOT LOAD PAST THE STARUP SCREEN IVE TRIED HOLDING THE POWER BUTTON DOWN BUT IT STILL JUST STAY ON THE START UP SCREEN WON'T LOAD INTO THE GPS (PLEASE HELP NEED IT FOR WORK)
There is a tendency that the unit is not properly charge try to charge the unit for 3 to 4 hours by using a wall adapter and after 4 hrs press and hold the power button for 10 seconds then release.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Tomtom XL 330S GPS Receiver
My delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
Tomtom ONE GPS Receiver Logo
42 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
