Question about Kwikset Professional Door Lock installation Kit
Cannot remove disk that covers screws to tighten my lock
We can get the handle off but not the disk that is located against the door itself where we presume that screws are located to tighten the lock set
  • 10 Answers
Most pop off by gently prying off with a small screwdriver. Some can be removed by turning counterclockwise a quarter turn. Please remember to rate my answer
Posted on Aug 07, 2009
How do I remove the inner door panel on a 2007 GMC Yukon XL Denali to get access to the door opening/lock rod system?
Welcome to Fixya
Disconnect the negative battery cable first to ensure your safety. You will see a small trim panel a few inches above the interior door handle (behind the armrest). Pry off the panel with the trim panel tool or a flat-head screwdriver. Remove the two 10 mm bolts that are behind the small trim panel. Pry off the vertical trim panel mounted on the handle that connects the power window controls and the door panel. Once the panel is removed, use the socket wrench to pull out the two bolts behind it. Pry off the small plastic piece around the door lock tab (upper part of door handle). Once the piece is removed, detach the door lock tab with your hand. Unfasten the sail panel using the trim panel tool or the flat-head screwdriver. The sail panel is on the corner of the door panel, directly across from the outside mirror. The panel is only attached by clips. Pull your interior door handle toward you, and pry off the trim panel behind it. Remove the bolt made visible with the panel removed. Pry up the power window control panel. Then unhook the electrical harness from the rear of the panel. Use the door trim tool to unhook the door panel clips. Insert the tool between the door panel and the door, and release the clips. There are several clips on each side of the door panel. Push the door panel up, then pull it away to remove it from the door.'
Thank you for using Fixya!
Aug 21, 2011 | 2007 GMC Yukon XL Denali
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
THE HANDLE WHICH LET YOU GO FORWARD AND BACK IS VER LOOSE - IS THERE ANYWAY TIGHTEN IT
hiplady yep you might have to remove the console on the tiller which is held on by phillip screws located under the console. After you have all the screws out maybe 4 -6 screws depending on the type scooter console cover you have. Carefully remove the plastic cover and you should be able to see the throttle handle. It is held in place by a nut that tightens against a plate that the post goes through. That nut is loose or check to make sure that the plate holding the throttle handle is not loose on the tiller itself(some are held on by screws some are welded to the tiller) If you can tighten the nut between the throttle handle and the plate. Hope this helps you
Oct 11, 2010 | Pride Mobility Products Health & Beauty
Door handle need to be re tightened. Do you hav...
if its just the handle itself it sounds like the fixing clips have come adrift or broken off,the handle strip will need replacing if its the whole console thats loose remove the outer door cover this will give you access to panel screws and may allow you to see more of the handle fitting inside.
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The screws are located on the non locking side of the handle. To get the cover off most pop off by placing a small screwdriver behind the edge and gently prying. Paint/varnish will make this harder so you my have to take a razor and cut around it.
Please rate.
Jun 03, 2009 | Kwikset Professional Door Lock...
I nee to tighten up the freezer door handle on a sub zero 650?
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Apr 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Remove right rear door panel
  1. Remove the rear door power window/power door lock switch
  2. Remove the door handle bezel. Remove the door trim panel screw located behind the door handle bezel.
  3. Remove the door trim panel screws located by the armrest handle.
  4. Remove the door trim panel using J 38778.
  5. Disconnect the electrical connectors.
  6. Remove the door trim panel from the door.
INSTALLATION PROCEDURE
IMPORTANT: Discard the old door trim panel retainers and replace with new retainers before installing the trim panel
  1. Install new trim panel retainers to the rear door trim panel.
  2. Connect the electrical connectors.
  3. Align the door trim panel retainers to the door.
  4. Press the door trim panel at the retainer locations until the retainers are fully seated.
  5. Install the trim panel screws. Tighten Tighten the door trim panel screws to 2 N.m(18 lb in) .
  6. Install the power window/power door lock switch
Nov 04, 2008 | 1998 Oldsmobile Intrigue
Handle is loose on GE Monogram Model# ZFSB27DAG SS. How do I get thehandle tightened up? No steps have been taken to fix problem. Stirwin
handle secured by 4 stainless stand offs on each door correct?, i would look closley at the underneath of the standoffs should be a screw to tighten/loosen. . actually lookin at diagram theses are comlete doorskins wrapped around the door itself you might need to remove teh screws on top and bottom ofr door skins and tighten from behind s/s skin
Mar 04, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Kwikset Professional Door Lock installation Kit Logo
470 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
