Question about Asko 1595 Dishwasher
Akso Dishwasher Model 1595 F2 Error Message
Hi -- I recently rented my house. Within a week, the renters called saying the dishwasher was leaking water out the front and down into the basement and the kitchen sink was clogged and overflowing. I called a plumber who cleared the line in the kitchen sink, so it's draining correctly, but now have a flashing F2 error message on the ASKO dishwasher model 1595. Any ideas? Do I need to call a repair person?
  • michelle_rut Jun 02, 2009
    Yes -- sorry have to go...
    Sergeant:
  • 187 Answers
Hi, Try these... -Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
The Duet hides the pump/filter access behind the lower panel. Most LG, Miele and ASKO washers have it right up front for easy access. I guess keeping such a base element out of view helps sales.
Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump
pls rate my suggestion..Hope u giv me a good rating...
Posted on Jun 02, 2009
I have a GE Potscrubber dishwasher which is about 13 years old. I recently experienced a problem when I ran the dishwasher I had water leaking onto my floor. In addition, the cycle had not used all the...
The pump seal may be the problem. There are a number of places on the net where you can get step by steps and the the parts to replace the seal. Some recommend just getting a new motor pump housing which is 150. I just purchased the impeller assembly (it has all you need) and it cost $25 with shipping. Only thing is I did not realize I also had a leak in the solenoid stem valve. Let me know if you need the link I was talking about.
Dec 08, 2010 | GE Dishwashers
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Fisher & Paykel Dishwasher
f2 refers to a motor error, you have the manual??? if not hereit is, try taking apart( its mean t for you to be able to service your self, its explained in the manual as to hoe to gfe down ther, the motor/ also called rotor is located within the drawer itself and under the silver screen every compponent twist out to reveal the next look for something under there somewhere preventin the rotor from spinning freely
http://www.fp.co.nz/admin/pdfs/pdf_usecares/527972D_DD_UserGuide_NZw.pdf
Apr 08, 2008 | Dishwashers
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
May 28, 2007 | Asko 1595 Dishwasher
F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
May 21, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
203 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
