Question about Hubbell Electrical Products 2 Gang PVC Outlet Box with Clamps
"Double" electrical switch has failed to function
This is an "electrical" problem, but I don't see such a catagory. I have a bedroom light that can be turned on/off from either the wall or the bed. Suddenly, the wall switch has stopped functioning, while the be switch still works. What could the problem be?
  • 864 Answers
In a standard 3-way switch arrangement you can turn the light on or off from each position.  If the wall switch has failed then only the bed switch will turn the light on/off.  Replace the wall switch with a new 3-way switch.
Posted on Jun 02, 2009
How to turn off floor lights
Hi Bill,
This sound like a simple switch failure.
1. Isolate the power.
2. Disconnect the load from the switch and make safe.
3. Reinstate power.
The lights should be off thus indicating switch failure. Replace the switch. If the lights are still on then you have a double feed to the circuit which requires further investigation by a competent person.
Apr 22, 2016 | Miscellaneous
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
I have no up stair lights after going to turn on bedroom light nothing I noticed that the other bedroom lihgt had gone out so I changed the bulbs and the fuse in the fuse box made no difference Ithen...
hi if the rose has caused the problem then the mains wire may be damaged, it can also damage the fuse RCB0 B6 fuse, this will not let power though until the fault is fixed. it would be best to get an electrician to fix this problem as its dangerous to open the fuse box to fix the problem.
Jul 15, 2017 | Office Equipment & Supplies
Wiring a 2 gang light switch
Okaaay, but which is the permanent live from the lighting circuit, which is the switched live back to the ceiling light, which is the neutral from the lighting circuit?
You may need to open the ceiling rose to see how the red/yellow/blue are wired.
On the switch the terminals are usually diagonal, ie L on the top matches with L1 and L2 on the bottom. L1 and L2 on the top match with L on the bottom.
So you want permanent live from the lighting circuit to go to L and a short piece of wire linking that to the other L.
One of the L1 is switched live back to the lighting circuit.
Other L1 is switched live to the cabinet light. (Red?)
Presumably you also need to connect the neutral from the lighting circuit to the neutral to the cabinet light. (Black?)
bedroom lights
Jun 04, 2012 | Electrical Supplies
Had working sky remote in bedroom, now no remote sky operation from upstairs, is there a secret installer code to switch this function on?
Have you got a magic eye in the bedroom,if so the little red light should be on,if it is not then you are not getting a signal from the main box.You need to check the 2nd rf output is switched on in the main box.
Nov 02, 2009 | Televison & Video
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Fan/stove light switch broke needs replacing
The original fan switch for the SEG196 (circa 1995) is a four terminal switch- two for the fan and two for the light . Note that the switch spade lugs for the red and blue wires (which when connected activate the fan) are larger than those for the white and brown wires (which when connected activate the oven light). This design presumably prevented miswiring of the switch at original assembly. Since the four terminal switch is nearly impossible to find (it was discontinued several years ago), an inexpensive fix is to replace the four wire switch with a two wire SPST toggle switch. However, this means that either the fan function or the light function can be preserved- not both. I elected to keep the fan function, and simply wired the red & blue wires to the two terminals of a heavy duty replacement SPST toggle switch. Be sure to fully insulate the remaining (in this case) white and brown wires with electrical tape or wire nuts before tucking them below the new switch. Total cost: $6.00 for switch. NOTE: TURN OFF POWER TO RANGE AT ELECTRICAL PANEL BEFORE ATTEMPTING REPAIR! beec3807-1ba5-40e7-a010-7e26d5fca5c0.jpg
Feb 18, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
My daughters lights
Sounds like you may have possibly one or two three way switches improperly wired.
Without actually seeing the circuitry is will be hard to diagnose without more information.
Aug 06, 2008 | Dryers
Hubbell Electrical Products 2 Gang PVC Outlet Box with Clamps Logo
255 people viewed this question
Top Hubbell Electrical Products Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Hubbell Electrical Products Electrical Supply Expert? Answer questions, earn points and help others
