Question about EliteGroup Goal 3 Plus/Sempron 3000+ Motherboard
USB Ports Not Recognized. XP says they are working properly
Back connectors and motherboard headers not recognized. Its as if there is no power to them. Help
  • 166 Answers
Conection to the mother board . get a new computer
Posted on Jun 02, 2009
Usb header not working
Usb ports are bogus. You can always install a pci usb card though. Beats replacing the mo bo since you have already tried everything else to no avail.
Apr 15, 2017 | ASUS M2N-MX SE Motherboard
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
The USB port on my Elitegroup K7S5A Motherboard does not work, even i've installed the right driver and the latest updates of Windows XP. Someone any idea why?
It may be the operating system has not recognized all the ports, if you operating system is now ok, go to my
computer>properties>hardware>device manager, and look to bottom of the list to USB Controllers.
Right click on them, and Uninstall all controllers and restart pc and see if all the ports are recognized and installed
automatically.
Go back to the controllers after restart and ensure there are no'!' ? marks or no 'X' against any controllers.
Hope this helps,
Jan 13, 2011 | EliteGroup K7S5A Pro Motherboard
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
PROCESSOR, MOTHERBOARD AND POWER
This is a printout of the specification for the Gigabyte motherboard GA-MA785GT-UD3H
products_spec.aspx&websource=www.google.com.au%2fsearch%3fhl%3den%26q%3dgygabyte%2bga-ma785gt-ud3h%2bspecs%26btng%3dgoogle%2bsearch%26meta%3d%26aq%3df%26oq%3d&sourceweb=
arrow_down_deepgray_7x7.gif Specifications CPU
  1. Support for AM3 processors: AMD Phenom™ II processor/ AMD Athlon™ II processor
Hyper Transport Bus
  1. 5200 MT/s
Chipset
  1. North Bridge: AMD 785G
  2. South Bridge: AMD SB710
Memory
  1. 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory (Note 1)
  2. Dual channel memory architecture
  3. Support for DDR3 1800(O.C.) /1666/ 1333/1066 MHz memory modules
Onboard Graphics Integrated in the North Bridge:
  1. 1 x D-Sub port
  2. 1 x DVI-D port (Note 2)(Note 3)
  3. 1 x HDMI port (Note 3)
Audio
  1. Realtek ALC889A codec
  2. High Definition Audio
  3. 2/4/5.1/7.1-channel
  4. Support for Dolby Home Theater
  5. Support for S/PDIF In/Out
  6. Support for CD In
LAN
  1. Realtek 8111C chip (10/100/1000 Mbit)
Expansion Slots
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16_1) (Note 4)
  2. 1 x PCI Express x16 slot, running at x4 (PCIEX4_1) (Note 5)
    (The PCIEX16_1 and PCIEX4_1 slots support ATI Hybrid CrossFireX technology and conform to PCI Express 2.0 standard.)
  3. 3 x PCI Express x1 slots (The PCIEX1_2 and PCIEX1_3 slots share the same PCIe bus with the PCIEX4_1 slot.) (Note 5)
  4. 2 x PCI slots
Storage Interface South Bridge:
  1. 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
  2. 6 x SATA 3Gb/s connectors supporting up to 6 SATA 3Gb/s devices
  3. Support for SATA RAID 0, RAID 1, RAID 10 and JBOD
iTE IT8718 chip:
  1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394 T.I. TSB43AB23 chip
  1. Up to 3 IEEE 1394a ports (1 on the back panel, 2 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
USB Integrated in the South Bridge
  1. Up to 12 USB 2.0/1.1 ports (6 on the back panel, 6 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
  1. 1 x 24-pin ATX main power connector
  2. 1 x 8-pin ATX 12V power connector
  3. 1 x floppy disk drive connector
  4. 1 x IDE connector
  5. 6 x SATA 3Gb/s connectors
  6. 1 x CPU fan header
  7. 2 x system fan header
  8. 1 x power fan header
  9. 1 x front panel header
  10. 1 x front panel audio header
  11. 1 x CD In connector
  12. 1 x S/PDIF In/Out header
  13. 2 x IEEE 1394a header
  14. 3 x USB 2.0/1.1 headers
  15. 1 x parallel port header
  16. 1 x serial port header
  17. 1 x chassis intrusion header
  18. 1 x power LED header
  19. 1 x clearing CMOS jumper
Back Panel Connectors
  1. 1 x PS/2 keyboard or PS/2 mouse port
  2. 1 x D-Sub port
  3. 1 x DVI-D port (Note 4) (Note 5)
  4. 1 x HDMI port (Note 5)
  5. 1 x optical S/PDIF Out connector
  6. 1 x IEEE 1394a port
  7. 6 x USB 2.0/1.1 ports
  8. 1 x RJ-45 port
  9. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
  1. ITE IT8718 chip
H/W Monitoring System voltage detection
  1. CPU/System temperature detection
  2. CPU/System fan speed detection
  3. CPU overheating warning
  4. CPU/System fan fail warning
  5. CPU/System fan speed control (Note 6)
BIOS
  1. 2 x 8 Mbit flash
  2. Use of licensed AWARD BIOS
  3. Support for DualBIOS™
  4. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
  1. Support for @BIOS
  2. Support for Q-Flash
  3. Support for Xpress BIOS Rescue
  4. Support for Download Center
  5. Support for Xpress Install
  6. Support for Xpress Recovery2
  7. Support for EasyTune (Note 7)
  8. Support for Easy Energy Saver
  9. Support for Time Repair
  10. Support for Q-Share
Bundle Software
  1. Norton Internet Security (OEM version)
Operating System
  1. Support for Microsoft® Windows Vista/ XP
Form Factor
  1. ATX Form Factor; 30.5cm x 22.9 cm
Note (Note 1) Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connection by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) If you are installing a PCI Express graphics card, be sure to install it in the PCIEX16_1 slot.
(Note 5) The PCIEX1_2 and PCIEX1_3 slots share bandwidth with the PCIEX4_1 slot. When the PCIEX4_1 slot is populated with a x4 card, the PCIEX1_2 and PCIEX1_3 slots become unavailable.
(Note 6) Whether the CPU/system fan speed control function is supported will depend on the CPU/ system cooler you install.
(Note 7) Available functions in EasyTune may differ by motherboard model.
Aug 07, 2009 | Gigabyte Computers & Internet
Usb & Front panel Problem..!
these front usb ports cause prob lem always kindly change the whole panel with usb ports in front they are faulty and giving problems and will create more problems if u dont change them kindly get new one u can find them easily on any store and simply chang them see the connector going to the motherboard plug it out and plu the new one at same location
rate me WELL !
Regards
May 23, 2009 | Gigabyte Computers & Internet
When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY
Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
May 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Trying 2 figure out what type of memory 2 use?
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
Feature
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Processor
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
200/266MHz
Chipset
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
Memory
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Certifications
FCC, CE, BSMI,WHQL
Form Factor
Micro-ATX (218mm x 244mm)
Jul 11, 2008 | Intel Motherboard
EliteGroup Goal 3 Plus/Sempron 3000+ Motherboard Logo
100 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
