Question about Acer Aspire 5100 Notebook
Tring to run restore disk but laptop kepts shut down
Tring to run recovery disk but laptop kepts shut down before process is done
  • 192 Answers
Maybe it's shutting down because it overheating. Check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent. You can also try running your restore disk with the laptop sitting right next to a window A/C unit. Try to position the laptop so it gets maximum exposure to the cold air of the A/C unit.
If you get the laptop working again and you think overheating is a problem I recommend downloading a free piece of software named FanSpeed. Here's a link.
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
Posted on Jun 02, 2009
    Problem Solver:
  • 9 Answers
Restore the system in safe mode.
Restore factory settings
Many Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden system recovery image, you can restore your computer to its factory-fresh software condition by following these steps:
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. Press and hold down the 0 (zero) key on the keyboard while powering on the computer. Release it when the recovery warning screen appears.
  5. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. A warning screen appears, stating that when the recovery is executed all data will be deleted and rewritten.
  7. Click Yes to continue.
  8. When the Toshiba Recovery Wizard opens select "Recovery of Factory Software" or the appropriate option for your needs.
  9. Continue to follow the directions restarting as necessary.
For laptops equipped with Windows 8, "Reset" returns your computer to its out-of-box, factory default conditions (removes your personal files and apps as well reset all settings to defaults) similar to a "System Recovery."
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will restart your computer several times.
As you use the recovery process you will have several options. One of these may be to create a custom size partition. Follow the directions on screen for this and other options as prompted. When in doubt, it's usually best to accept the default, or pre-selected option.
Nov 30, 2013 | Toshiba Satellite A45-S150 Notebook
CANT RESTORE MY COMPUTER
It is asking for the recovery discs that should have been made in the event there was a problem with the recovery sector on drive D or the hard drive failed. The only option is go to www.hp.com contact customer support and the technical department to see if they can sell you the much needed discs.
May 08, 2012 | HP Pavilion a420n PC Desktop
Yes I have forgot my password on my toshiba Satellite L3550 and I cant do any thing on my laptop. I dont have a boot disk either, is there anything I can do to beable to use my computer again
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
Restore Partition C: of HDD without changing current partition size
CAUTION:
Restoring the C: drive to its factory default state formats your drive. Your information on the drive will be overwritten, and lost. Be sure to back up all important files first. If you have created other partitions (for example, a D: drive) those partitions and any information on them will not be affected and will remain intact.
To restore only the C: drive:
  1. Press 2 to restore only the "C:" drive (the letter C is traditionally used to designate the first volume on the hard disk drive) on your computer. A confirmation message will appear, indicating that all information on the drive will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
Restore Image to C: Partition with user specified size
CAUTION:
Resizing and restoring your C: drive to its factory default state formats all partitions on the HDD (for example, if you created a D: drive, it will be deleted during the recovery process) your information will be overwritten, and lost. Be sure to back up all important files first.
To resize and restore your C: drive:
  1. Press 3 at the Toshiba HDD Recovery Utility screen. A confirmation message will appear, indicating that all partitions will be reformatted and all information will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click "Yes" to begin the recovery and to specify the size of the C: drive.
    • Press the Left/Right Arrow keys to increase/decrease the C: drive size by 1 GB increments.
    • Press the Up/Down Arrow keys to increase/decrease the C: drive size by 5 GB increments.
      NOTE:
      The size of the C: drive will be displayed on the progress bar as you make your selections.
  3. Click "Enter" to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
  4. Press any key to restart the computer.
Aug 12, 2011 | Toshiba Satellite L355D-S7815 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
CAUTION:
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
My HP pavillion dv7 keeps shutting down. I'm trying to run a system recovery back to the factory settings. It got up to 51% done and then the laptop shut off. Subsequent attempts at booting it back up...
Be sure that the laptop is plugged in to the power supply before you start! Are you restoring from an image in the machine or a CD or DVD disk?
Either way this takes quite a while and most manufactures warn you that the machine will reboot a few times (I have seen some take 5 reboots) to complete the task, so be patient.
The last part of your question concerns me. If you power cycled the computer (turned it off then on) half way through the process it could be hard crashed. If you have the CD or DVD dish this would not be a big problem but if you are restoring from an image this could be bad. Let us know.
Ron
Jan 06, 2011 | HP Pavilion DV7-1232nr Notebook
I get this problem and can't get past it help please Unmountable_boot_volume its a problem with the recovery system a blue screen for dell inspiron 2650
I sure hope you kept a recent backup. Something has gone terribly wrong in there. If you didn't keep a recent backup, do you still have the Windows setup disk(s), or the Recovery disk? It sounds like you will need to do one of those. STRONG ADVICE_ DO NOT start to run a Recovery or Resoration disk NOR a backup and then stop it part-way done! I did that recently, and it took me 3 months to find a solution. It deletes all your partitions. Then nothing will work without much research and work. Once you start a recovery from a disk or a backup, let it finish! It may take awhile, but it's worth it. Don't panic. Just do a backup restore or a restoration disk, and any lost data, will be lost. People call using the Restoration CD a "reformat". It gives you a fresh install of Windows. Try to always keep a recent full partitions backup, it's worth it's weight in gold. Feel for you!
Dec 21, 2010 | Computers & Internet
I need to do a system restore but i no longer have the disk that came with my laptop. has anyone got any suggestions besides junking this laptop and getting a new one not really an option ( low on funds ).
hi if you have access to the operating system then you will need to find the following hidden file to start this restore process,,,,
D:\HP_Recovery\MiniNT\System32\start.exe
double click and it will prompt you with HP warning about altering/deleting files click to accept and finish the process.
Hope this helps Rate Me please MISTERDJ
May 09, 2010 | HP Pavilion zd8000 Notebook
Laptop format
Just bought Lenovo S10 and so unlucky that window crashed. So have to restore my Lenovo S10 to factory settings. Can’t really find how ot restore to factory settings in Lenovo S10 from the User Manual. So check from google, after many many search, finally found the solution.
For Lenovo S10 to restore to factory settings follow the steps below:-
  • Turn off your Lenovo. (i mean shut down and make sure it’s power off)
  • Now press on the “One Key Recovery” key at the top of your Keyboard, your Lenovo S10 should boot up. Else hold down the “One Key Recovery” key until it boot up.
  • Now you may choose “Restore to factory settings” from the screen and proceed for the restoration.
    ** the restoration will first check if your windows files has been corrupted, if yes, then it will restore it to the original state and no restore is required. else it will continue with the restoration
Apr 15, 2010 | Lenovo IdeaPad S10-42312CU Notebook
Loading PBR for descriptor 2...done
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Will not start up after system recovery done with disks.
Try uninstalling your sp2 or any updates a restore from an early date before the update
Aug 28, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
