Question about Symphonic WF20D4 TV
Whats the tv remote code if i have a direct tv + remote.
Re: Whats the tv remote code if i have a direct tv +...
The Directv remote isn't capable of fully emulating the native remote of the Symphonic Combo. You can get limited functionality though.
1. Move Remote slider to "AV1" position.
2. Hold down mute and select until you get 2 flashes of the green light, then release both keys.
3. Enter 20821 and observe 2 more flashes of the green light.
Next lock the volume controls to this device.
4. If you have moved the remote's slider from the AV1 position, move it back. The slider should remain on AV1.
5. Hold down mute and select until you get 2 flashes then release both keys.
6. Enter 993 and observe 2 flashes.
7. Press and release THE SELECT KEY and observe 2 more flashes.
You can control the TV's power using the big power button under the device selector.
Posted on Mar 05, 2008
Symphonic tv remote control code for the RCA digital converter box I found by accident was #174. The RCA list was incorrect for this TV. Try 174 program code in the RCA remote to program the remote to the TV. Of course this doesn't work for the DVD player part of the TV.
Posted on Jul 11, 2008
Pl. tell me how to use my universal remote in my symphinoc tv
Posted on Jan 06, 2008
0 characters
3 Points
Whats the code to the mitsubishi tv
You need the code for your remote, they are different for different remotes
Dec 02, 2014 | Mitsubishi CK-31304 TV
Direct TV remote control won't work with my new TV
These are 4-digit codes : 0054, 0030, 1454, 0020. Here are 3-digit codes : 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089. Try these.
Dec 06, 2007 | Philips Magnavox 27MS343S 27" TV
Remote control model, diagram and factory reset
Contact Hitachi directly to obtain a new remote control or search the internet for any of several suppliers of OEM remote controls. A universal remote control may or may not generate the particular code you mention but you can use its code search function to find a code that will work.
Feb 02, 2014 | Hitachi C21 F800S TV
Can't program tv into direct tv remote
hi! i have here a couple of codes for your starlite TV, just try them, 1036, 1484, hope this helps!!! goodluck!!!
Dec 26, 2009 | Starlite PC2010ATVD TV
Reprogram remote
Here are the DIRECTTV codes for Sansui TV's.
10463, 11409, 11904, 11911, 11929, 11935 / 10236, 10179,
11463, 10178, 10765, 10767, 11684 /
011, 076, 096, 0091, 0099, 0179, 0236, 0463.
Call your Direct TV provider for instructions for your remote or go to Direct TV's website.
Nov 04, 2008 | Sansui D 27" TV275 TV
Direct TV remote does not control TV on/off or volume.
I have some codes hope they will help. slid remote to tv and hold away from tv as u push mute and select till light blinks twice. then point at tv and try these. 10154-10236-10463-10178-10171-101179 good luck
Sep 25, 2008 | Emerson EWF2704 TV
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Jun 08, 2008 | Proscan PS32500 32" TV
T.v and universal remote
i have a remote it is a rca and it is being used for a Daewoo tv.I need the code/model number rcr311
Dec 20, 2007 | Daewoo DTQ-20U4SC 20" TV
Orion tv codes
try these codes for the orion tv:0121,0135 or 0035. good luck
Nov 03, 2007 | Orion1934 19" TV
Symphonic WF20D4 TV Logo
573 people viewed this question
Top Symphonic Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Symphonic Standard (CRT) Television Expert? Answer questions, earn points and help others
