Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Problems with Mac 10.5.7 Installation
Hi;
I can't seem to get my Ricoh set up properly on my mac. I managed to get the "PPD" properly installed, but when i try to print, first a page with "adobe 3.0" followed by a bunch of code comes up, and then many many blank pages follow. The machine is connected via USB to an Airport Extreme. Do i need another driver?
    Problem Solver:
  • 9 Answers
What program are you trying to print from on the Mac? I ran into a similar problem with Quark. here's that solution:
went through some Quark forums on line and read everything about printing problems with Quark 7 or 7.3. Most posts blamed the printer or the driver. However, the common theme was that it was only Quark and not earlier versions.the CUPS filter solution is no helpIn QuarkXPress, you can choose a data format to specify how the data for the pictures in your layout are sent to a PostScript printer: Binary, ASCII, or Clean 8-bit. Because binary data may be incorrectly interpreted through certain network printing protocols, or because your specific PostScript printer may not be able to interpret Binary data, you may need to change the data encoding method from Binary to either ASCII or Clean 8-bit. Please see the More Information section of this article for a detailed discussion of how these encoding methods differ.
Solution: Go to File > Print and select the Pictures pane. In the Data field of the Pictures pane, select either ASCII or Clean 8-bit.
Posted on Aug 29, 2009
Hi do you have the part number for the postscript 1515mf...
Posted on Sep 10, 2010
I need a driver for my Dell 3010cn for my Mac OS X.
Here is how to use the Dell 3010cn Color Laser Printer on Mac OS 10.6 Snow Leopard (or 10.3-10.5):
1) Install Ghostscript 8.64
http://www.openprinting.org/download...-8.64so-ub.dmg
2) Install Foomatic-RIP-4.0.2
http://www.openprinting.org/download...-4.0.2.211.dmg
3) Download the PPD
OpenPrinting database - Printer: Dell 3010cn
4) Add printer using USB or IP address (LPD or IPP protocol). Change driver from Autoselect/Generic to other, and find the PPD from 3).
Jul 16, 2012 | Apple iMac G4 17 in (M8935) Mac Desktop
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Where can I download the driver for Mac os x 10.5.8 to run a ricoh cl7200 please and what kind of size will the down load be. Thank you
Hi, you can get the CL7200 driver for a Mac OS X 10.5 from the Ricoh website here:
http://ricoh-usa.com/downloads/downloads.aspx?d=ds
Just search for CL7200 under Drivers, and then agree to the site's terms of service. The Print Utility download for the Mac is 319 KB; you can click the link under Download. You can also download the PPD Installer (193 KB) and the PANTONE Color Palette (11,261 KB).
Dec 29, 2010 | Ricoh Aficio CL7200 Laser Printer
Printer has worked fine for years with my pc's. Still prints the test page fine but wont' print since I switched to mac. Installed the print only file from hp website a couple times. Actually it does...
It sounds like the driver provided by the manufacturer may have a glitch in it. I would recommend sharing the printer to the MAC:
Add the Shared Printer to Your Mac Launch System Preferences by clicking its icon in the Dock.
Click the ‘Print & Fax’ icon in the System Preferences window.
The Print & Fax window will display a list of currently configured printers and faxes that your Mac can use.
Click the plus (+) sign, located just below the list of installed printers.
The printer browser window will appear.
Click the ‘Windows’ toolbar icon.
Click the workgroup name in the first column of the three-pane printer browser window.
Click the computer name of the Windows machine that has the shared printer connected to it.
You may be asked to enter a user name and password for the computer you selected in the step above.
Select the printer you configured for sharing from the list of printers in the third column of the three-pane window.
From the Print Using dropdown menu, select the driver that the printer needs. The Generic PostScript Printer driver will work for almost all PostScript printers, but if you have a specific driver for the printer, click ‘Select a driver to use’ in the dropdown menu, and select the driver.
Click the ‘Add’ button.
Use the Default Printer dropdown menu to set the printer you want to use most often. The Print & Fax preferences pane tends to set the most recently added printer as the default, but you can easily change that by selecting a different printer.
Oct 03, 2009 | HP LaserJet 2550n Printer
How to use gestetner dsc224 as Mac OS X printer
You need a PostScript (PS3) DIMM for the DSC224 so it will understand what the Mac is saying to it. Obviously the machine has network print option installed, otherwise there would be no response at all. The PS3 DIMM installs on the print controller board. If I remember correctly, (looking from the rear of machine), left side behind outer cabinetry......a bit deeper, then behind metal RFI shield,,,the proper slot is labeled on controller pcb....if not labeled, it will be the only slot open for this sized DIMM. I must admit, it has been 3 or 4 years since I've assembled one of these models. Hope this helps.
Sep 05, 2009 | Gestetner DSc224 Copier
Ricoh Adicio on a mac
Your machine requires the Postscript option installed in order to print from your Mac. The printer is printing gibberish because it cannot understand the postscript driver from the Mac. .
Jul 22, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
OS-x driver for Brother HL-730 (600dpi) printer
Macs don't use drivers, but rather .ppd files.  you should be able to download the PPD from brothers website:  http://www.openprinting.org/ppd-o-matic.cgi?driver=hl7x0&printer=Brother-HL-730&show=0
(Direct Download Link)
When you are in system settings, goto printers, select the network printer, and when you get to choose the PPD from the pulldown menu choose "Other" and you should be able to browse to the PPD you downloaded.
you are using a UNIX based system.  The Linux PPD should work just fine.
Apr 08, 2009 | Apple iMac G4 Desktop
From mac leopard cannot print duplex on minolta qms 3100 printer
Hello, sorry you are having problems,
OK, are you sure your printer supports duplex printing and if you are sure you have the right driver installed, this is how you print in duplex mode on a Mac.
Open the document you want to print, Hit cmd+p to get the print dialogue window you should see this: 46da167.png
Notice you have the option of two sided printing in the same line as # of copies.
If you do not have this option in 10.5.6, then you might have the wrong driver, N.B. you must be sure to select the proper driver when you are creating the printer in the Print and Fax preference. Another way to ensure you have the driver properly installed, go to the manufacturer's website and download the Mac Driver Installer and run the installer, delete the printer you created and then re-create the printer again it should auto-recognize the printer..
What is the Printer Make and Model?
Mar 07, 2009 | Apple Computers & Internet
BizHub 250 Printer Driver
Hi, which version of Mac OS have you ? what are your problems ? also, i ve sent the ppd necessary for the Bh250 Mac driver on http://crackzfr.free.fr/bh250.sit. You'll have just to register it on your mac and, you'll be able to print on your Bh...
Jan 06, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
Oct 08, 2007 | Ricoh Aficio BP20N Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
279 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
