Agitator was screeching, now there is grease/oil stains on clothes
My machine was making screeching noise when agitating. Last night when the load finished, there were several oil/grease stains on the clothes. And there are still stains on the bottom of the drum.
  • jdufault Jun 02, 2009
    Thank you.  I've been searching for a free service manual, do you know where I can find one online.
    President:
  • 1,902 Answers
Main seal and bearing have gone bad and needs to be replaced
Posted on Jun 02, 2009
  • Jeremy Reddick
    Jeremy Reddick Jun 02, 2009
    What is the make and model I would be happy to look for one for you. Or you can just go to the makers website
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Getting grease or oil spots on clothes when washing. Machine is not making any odd noises. It has a stainless steel drum. Never had a problem with this machine. It's a commercial version for homeowners. ...
If you get grease-like marks on your clothes after a laundry cycle, and they wash out in the next load, don't despair. It's a sure bet they're caused by detergent and fabric softener that have congealed on the underside of the agitator or along the top edge of the washer basket.
To eliminate the problem, first clean any crud from the gap along the top of the washer basket. Then remove the agitator and clean the gunk off the underside. Since the agitator removal procedure varies by manufacturer, go toallplianceguru.com and search for your make and model. After youve cleaned the agitator, reinstall it and fill the tub with hot water. Next, dump in 8 oz. of washing machine cleaner (Washer Magic is one brand; buy fromamazon.com or applianceparts stores) and run it for a full cycle without any clothes. That should eliminate the problem. If not, repeat the procedure.
Happy Holidays
Dec 13, 2010 | Speed Queen AWS44NW Top Load Washer
What will cause black grease stains on clothes in a GE washer, when the clothes are not greasy going in. Agitator seems a little loose.
It maybe a bit of grease worked it's way down inside the agitator,check if there is a way to "torque" down the device.
Mar 28, 2010 | GE WJSR2070B Top Load Washer
Seems to bee grease getting in from sum where as
Take off the agitator and look for signs of oil coming from under collar that supports the agitator.
If so it means that the seal has gone and water has got into the transmission forcing the lubrication oil to be pushed up through the seal.
Big job to repair.Sorry
Feb 23, 2010 | Westinghouse WWS833ES Super Capacity Top...
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
Washing machine stains clothes
You can pull the agitator straight up and off to check if there is any grease / oil on the bottom of it. You may have to use a belt or similar item to slip under the agitator and attach the other end to a broom handle to pull up if it is difficult to remove. If there is grease / oil, it is not very easy or inexpensive to repair. The average life of a washer is about 9 years, so this one doesn't owe you anything. I'd look into a new front load unit which uses much less water and spins clothes out at 2X or more the RPM's of your current machine. Please don't rate this solution as anything but a FixYa rating will lower my overall score. Thanks.
Nov 19, 2008 | Washing Machines
Leaves
with the exeption of something you mistakenly left in your clothing and wound up in the washer, not likely stains are from there , most of the time they do come from the dryer, try grabbin an old white rag nad runnig it around hte fron of hte dryer drum and then tyr the rear where the drum meets the back bulkhead. usually leavs brownish streks smome what curved 2-3 inches log. its from hte felt hte supposed to seal the drum. its either wearing thin, or a glide has worn away causing the issue
Mar 22, 2008 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
428 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
