Question about Kenmore Food Mixers
MIXER IS VERY LOUD. SCREECHING NOISE
KENMORE 16 SPEED STAND MIXER -MODEL 238.69253. THIS MODEL HAS A HIGH SCREECHING NOISE WHEN YOU RUN IT. SO BAD THAT MY WIFE HAS NOT USED IT FOR ANYTHING SINCE I RECEIVED IT. IS THEIR SOMEBODY OUT THER THAQT COULD HELP US! jcderouche804@myfairpoint.net
  • 16 Answers
SOURCE: My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed ....
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem (but mine occurred with a 600 professional model) and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.
Posted on Dec 30, 2008
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
SOURCE: how to buy accessories for the kenmore stand mixer model 23869253
The Kenmore 600 Watt Stand Mixer uses KitchenAid Accessories.
Posted on Apr 03, 2009
  • 143 Answers
SOURCE: My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Posted on Oct 12, 2009
hslincoln
  • 235 Answers
SOURCE: I have a KitchenAid Pro 600 stand mixer, and it
It appears that you've got some internal transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. It could be as simple as the gears have become loose and are making different contact, hence the noise. The higher the speed, the louder, higher pitched sound you'll get. It may also be indicative of a potential gear failure (after all our increasing noise, the bevel gear broke and the mixer 'froze'). If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
Posted on Oct 31, 2009
It just quit while I was using on high speed.
The lady's model is a K45SS and it does not have a Hall Effect Senor, Her machine di not go to high speed, it STOPPED!!, and that is all we know. If the mixer motor still runs or operates then it is a gear problem and yes it would be the nylon worm gear made to fail in order to protect the motor from burning out. if it won't start at all no noise or movement then it is an electrical problem and it could be the speed control switch the brushes the phase control board the govorner or the motor. what is needed is more information from the lady seeking help.
Dec 12, 2012 | KitchenAid K45SS Classic Stand Mixer
I purchased a used Kenmore Stand Mixer Model KSM100 that makes a loud grinding noise when its running. I need a manual and advise on how to repair it.
I am sorry Roland. I have searched for this manual but it appears to be unavailable.
You can post a request on www.manualsonline.com and someone who has a similar product may upload it for you.
By the way this service on Fixya.com is only for sourcing manuals and not providing service information.
The grinding noise may be due to bearing failure in the motor or gear failure.
Sorry I can't be of more help.
Oct 03, 2011 | Kenmore KSM100 Stand Mixer
Mixer makes a loud ticking or clicking sound at low to moderate speeds, like a clock tick. At faster speeds and high speed, the loud tick is drowned out by a louder grinding sound. All of this sounds...
I don't have a direct answer for you. There are many things which could cause the noise from a beater simply hitting the bowl to internal gear problems. You did not say which model you have so take a look at the two Service Manuals linked below. One of these ought to cover your machine.
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
Apr 06, 2017 | KitchenAid Food Mixers
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Jun 20, 2008 | Hobart A200 Stand Mixer
Kitchen aid KSM90
If you can unplug the mixer and test resistance between leads of the selector switch. The resistance should vary from high to low as you move the selector from low to high. If cord and all else looks good and switch is bad replace the switch.
Mar 23, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
Food Mixers Logo
135 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
Darial Jr Lasaria
Darial Jr Lasaria
john h
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
