Question about Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range
Igniter keeps clicking, intermittent
One burner on my Viking stove has a faulty igniter or something--ti continues to make a clicking/sparking noise after it ignites. How can I fix this?
    Problem Solver:
  • 13 Answers
There should be a little switch that slips over the stem of each burner control. Very common.
Posted on Jun 02, 2009
Viking 6 burner, gas stove top. When the back leftburner is turned on, it continually clicks. How can we fix this?
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
Gene
Aug 11, 2011 | Viking Kitchen Ranges
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
Left front burner not igniting...no spark but has gas,
automatic re ignition control (spark module), that's a common issue on all viking stove.
appliancesrepairla.com
May 12, 2010 | Viking VGIC485-6G Gas Kitchen Range
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
I hav a Viking professional. Only one burner ignites.
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking Stove electronic ignition keeps sparking
Why suddenly my ignition are not spark and did not light the flame on two burners?
Dec 26, 2008 | Kitchen Ranges
Viking Range
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Nov 15, 2007 | Viking VGSC366-6B Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Open Questions:
Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range Logo
1,964 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
