Question about Maytag MMV5207A Microwave Oven
No power I have a GE Profile Convection type microwave model JVM1190BY002..The unit has power to the printed circut board but has no display and will not turn on..Has a dark place on the board like it has been too hot but all the board ohms out with no opens...Can you help..I called a repair man out of the phone book and as it turned out he could not even tell it a fuse was good or not.......
  • Maytag Master
  • 9,086 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 02, 2009
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | Sharp R-1502 Microwave Oven
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
GE profile microwave
Most likely problem is your Smart card has fried.Its located on the removable panel that your display is attached to.If you remove the screws that open this Clock Panel (un plugged from power first) the display panel will swing down and you will see the circuit board I mention (Smart card/control board ).Look for a visible burn on this board.If you see one ,replace the board. Please Rate This !
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
NEED OPERATION MANUAL FOR 1998 MICROWAVE-CONZECTION OVEN mODEL JVM1190BY002
Go to geappliances.com. Select "Use and Care Manuals" under the Search drop down menu. Type in your model number in the adjacent window and select "Go". Your manual is available in a downloadable .pdf format. I hope this helps you.
Jul 23, 2008 | GE Microwave Ovens
Maytag MMV5207A Microwave Oven Logo
169 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
