Question about Kenmore HE2 Plus Front Load Washer
Will not start wash cycle - the drum rotates but then stops and displays F33
Displays F33
Try just to jiggle all the hoses.....it could be a simple clog
Posted on Jun 05, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Wash drum jams during cycle
Is the washer level? or are you maybe overloading it with clothes?
If those things are ok, I would look at the bearing point for the tub.It is either worn out, or out of round or not fastened properly. If you flip open the control panel cover, you may find a service technician's diagram on how the unit was assembled, and how it works electrically. Could be useful in pin pointing the part you need. Else check parts source.ca with your make and model number, and you might get a diagram there.
Aug 03, 2012 | Whirlpool Washing Machines
The washing mashine goes through the complete cycle but only starts the drun rotation every time the wash cycle comes and than after the apropiate time continiues through the full cycle without the timer?...
I hope you can explain once again the fault that is noticed as I am not able to judge what you have experienced.
If the DRUM is not rotating or is erratic in the cycle then it is possible that the program controller unit is a prime suspect.
The power to the drum motor seems to be erratic from the controller and so is making the drum turn out of turn. I thin when the controller is activated the drum rotates without a problem.
So please check your program controller unit.
Jan 18, 2011 | Zanussi Washing Machines
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
F33 error code. drum begins to rotate and then
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing Cycle won't start
Check the fill control switch. It has a small tube going to it.Clear the tube, and use a piece of tube to blow into the switch, it should click at about one to 2 psi, no harder than you can develop with your mouth. Make sure debris is not getting into the tube from the drum.
Apr 28, 2009 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
271 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
