Question about Brother GX-6750 Typewriter
Lift off tape
I was typing along and tried to correct an error. The lift off tape had been working fine. It will not lift the mistake up off the paper. We've tried changing the lift off tape but it still will not work. It is installed properly and is the correct type for our machine, which is a GX-6750.
  • Brother Master
  • 3,594 Answers
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Posted on Jun 03, 2009
How to correct mistake
Push the correction key, and it will automatically lift of the character, just make sure you are using a correctable ribbon with the liftoff tape.
Aug 15, 2014 | Lexmark Wheelwriter 1000 Typewriter
The correction tape is not working
If the correction tape is lifting properly try a resh ribbon and L/O they do get old.
DickyO
Apr 09, 2014 | IBM Wheelwriter 30 Typewriter
Typewriter does not correct
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Mar 21, 2014 | Brother ML-100 Typewriter
I installed the correction tape and it does not correct
Sounds like you have diagnosed the problem. Remove the correct tape and make sure that it's not the "sticky" type. (it will be hard to unwind if it is). Next try to manually lift the part that's supposed to move to see if it does. If it's sluggish (hard to move) put rags around it to prevent over spray and carefully clean all the moving parts with WD40. Make very sure that the WD40 does not get on any electronic parts! It will also mess up the platen. So, the more rags around the moving parts, the better. I used to work on IBM typewriters, and WD40 sometimes works wonders.
Jan 02, 2014 | Brother ML-300 Typewriter
I recently received lift off tapes for my nakjima typewriter. We have no user manual. I cannot get the ribbon and lift off tape to correct my errors. Please help or tell me if I am doing something wrong...
The ribbon may be noncorrectable, the knob must be orange or yellow. The lift off may be very old, or not properly installed, the dull side must face the paper.
DickyO
Sep 17, 2010 | Nakajima Office Equipment & Supplies
How to use correction tape
When you make an error simply press the correction key it should lift off, if itv dosen't either the ribbon or L/O tape may be old or both of them.
DickyO
Jul 21, 2009 | IBM Office Equipment & Supplies
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter Logo
281 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
