Question about HP Compaq nc6320 Notebook
Lcd screen getting broken!
I have a notebook, hp compaq nc6320, since a couple of years. Lately, the lcd screen started to display vertical stripes, 1 pixel wide, of different colours like cyan, yellow, purple. At the beginning it was one, now they are many and it starts to be a big problem. They appear just when the lcd is on, and after one stripe appears, it does not disappear anymore. How to fix this? Thanks a lot for your help!
  • imrik85 Jun 02, 2009
    could it be just a bad cable connection, or something like that? how i find the correct cable and panel if i need to replace them?
    thanks for your fast answer!
  • 53 Answers
You need to replace the LCD panel. go to the HP site and look for a replacement part.
Posted on Jun 02, 2009
  • Luis Perez
    Luis Perez Jun 02, 2009
    this URL "http://h20000.www2.hp.com/bizsupport/Tec... " will take you to the HP site for your laptop, try giving them a call to get parts for it such as the flat ribbon cable from the laptop body to the LCD lid for example. I don't think is just a bad cable though.
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
5 inch wide bands of colors on my computer screen... flashing...
you have a broken lcd screen and will need to replace it, if this appears from the moment you turn it on
Mar 15, 2011 | HP Compaq nc6320 Notebook
HP nc6320 black vertical line down the middle of the screen. A few days ago it disserpeared for a few seconds but then came back again
If the line is thick, it's a solder joint on the matrix controller - very hard to solder without the right equipment.
If it's a single pixel line, it's a bad contact right in the glass itself.
Single line defects can sometimes be repaired by placing sponge or rubber inside the LCD housing so that it presses against the LCD panel to force the contact back closed, but this is just a bandaid in most cases, and won't last long.
You will need to replace the LCD panel or get a new laptop if you cannot live with it.
Feb 22, 2011 | HP Compaq nc6320 Notebook
After turning screen ix initially blank although backlight is on. Gradually vertical stripes appear of varying width and colour. Eventually lines change to horizontal bars howing sections of the correct...
Your display is faulty. Check out ebay for a replacement. Changing the display is straight forward. If you get your display we can instruct you on replacing it.
Hope that helps.
Nov 09, 2010 | HP Compaq nx6325 Notebook
Fixing the faulty coloured vertical lines
Hi
It looks like the ribbon feeding the screen back to the base may have come loose or possibly even broken
I would recommend the following
1) Go into safe mode (swith the pc on and keep pressing F8 repeatedly until you have a menu presented to you, from the menu choose safe mode) and try there............if the same occurs then you will need to book it in and get a qualified engineer to look at it becaue it is hardware related
2) if it doesnt happen in safe mode then you will have to get the drivers reinstalled
However from what you are explaining it looks like you may be going down the option 1 route
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | HP Compaq nc6320 Notebook
My compaq display suddenly appeared a vertical black stripe dividing screen in two. Is there any solution for this issue?
restart your laptop if this problem occurs and check out for your graphics driver.
if problem persists, you have got some hardware problem..
Jan 27, 2010 | HP Compaq Presario C500t Notebook
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Monitor problem
My Friend, This one rings like a hardware malfunction with lcd. Try contacting contacting compaq/Hp
Jun 04, 2006 | HP Compaq Presario R4000 Notebook
HP Compaq nc6320 Notebook Logo
519 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
