I own a Hitachi external drive (Easy Drive) for back-up purposes. It has worked extremely well until yesterday. I absent-mindedly turned of the drive before disposing of the Hitachi icon. From then on, the drive has been on, cycling to find a computer. I get a message from my MAC Mini asking me to choose a WIRELESS device--an AirPort router. In my finder, I search under Devices to select the Hitachi external drive, but it is not available. All that's there is my computer drive. How do I get the Hitachi icon back in the finder so I can select it and sleep well tonigh? Thanks, Chris
  • chris_radant Jun 03, 2009
    Thanks, the new driver sounds great, but you gave me a link for Windows. I'm on a Mac. Can you steer me?
    Thank you.
    Chris
    President:
  • 1,383 Answers
U have to first uninstall usb drivers then install again
Posted on Jun 03, 2009
    Sergeant:
  • 296 Answers
Please download and install the latest drivers for the same.
http://www.bestdrv.com/hitachi_cdr_8130_driver_15573.htm
First uninstall any software that u might have installed previously and then install the drivers freshly downloaded from this site. If the drive is fine then the operating system should detect the drive . Incase the drivers are corrupt this download will take care of it as well.
Thank You for contacting Fixya.
Posted on Jun 02, 2009
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
My hitachi HTS545032B9A300 320gb usb external hard drive cannot be detected by any pc
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jul 06, 2012 | Hitachi Travelstar 5K500.B...
My hitachi external hard drive needs formatting how do i format
Just plug it into your computer, go into your desktop and click on My Computer, find the external drive that you plugged in, right click on it and scroll down to format, please keep in mind that all data will be lost once you start formatting drive. Let me know if this solved the problem and good luck..
Sep 09, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
My hitachi external hard drive dropped yesterday. There are no cracks gone on outter surface but my external hard drive now doesn`t read. As well as now the different internal sound is hear. But lights are...
Try to open the casing and disconnect the mobile harddisk inside from the connector. Then put it back firmly. Make sure nothing is loosen. If it still does not read, just plug the harddisk to a different enclosure to be able to retrieve the data
Jul 04, 2011 | Computers & Internet
Hi, yesterday my hitachi external hard drive is fallen to the floor and after that it is doesn't work. but the lights are working. i want know can i take my old data from hard disk and can it...
Dropping hard drives is a sure way of damaging the drive. There is no way us mortals can repair a damaged hard drive that has been dropped.
Retrieving data fromdamaged hard disk is possible. There are companies that can remove the diskplatters from the damaged hard drive and with special equipment may beable to recover your data, but it will cost you an arm and a leg for theirservices. The reason for this high cost, they dismantle and remove the plattersin the hard drive in a clean room environment and set up the platters up injig/drive to retrieve/copy the data.
Jul 04, 2011 | Hitachi Computers & Internet
How do I use the Hitachi ST/500 GB?
Firstly, you needed to tell us that this is an external hard drive, otherwise, how do we know..
Next, this drive plugs into a USB port where it will be detected by the operating system and added as another hard drive in your "my computer" and "windows explorer" listings.
Once the drive is added, simply drag whatever files you wish to place on the drive, onto the drive listing to copy them to the drive.
You can also use the "send to" menu item where the drive will also be listed.
select the file by right clicking on it, select send to then select the drive in the list that appears, easy..
dont place any operating system or everyday files onto the drive except for backup purposes.
Dec 19, 2010 | Computers & Internet
Hi, I have a simpletech/hitachi signature 160 gb external hard drive. It was fne until yesterday. Suddenly, my laptop is not recognizing it. what do I do?
Connect it to a different computer.
If it works, then connecting to _your_ computer is the problem.
If it does not work, then either:
* the USB-to-disk-drive adapter inside the casing has failed, or,
* the disk-drive inside the casing has failed.
Open the case, and remove the disk-drive, and connect it as a "slave" disk-drive in your computer, to see if the disk-drive itself is "good" or "bad".
Google-search for "Data Recovery Services" -- these are commercial, high-cost, companies, that can temporarily repair a "dead" disk-drive, just long enough to try to copy all the files from the disk onto a new disk-drive.
Jan 24, 2010 | SimpleTech Signature Mini 160GB External...
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi 160 IDE Hard Drive
You can download utilities from Hitachi here - http://www.hitachigst.com/hdd/support/download.htm You didn't say which drive you have, but one of the utilities there will allow you to run diagnostics on your drive, format, and partition it.
Jan 04, 2009 | Hitachi Computers & Internet
Using external hard drive for running applications.
FOLLOWING THINGS U SHOULD KEEP IN MIND WHILE GOING FOR EXTERNAL HARD DRIVE :-
1. PURPOSE OF EXTERNAL DRIVE - MEANS U WANT TO KEEP THAT TO USE IT FOR BACKING UP OF DATA?
2. DO THE COST EFFECTIVENESS OALSO EFFECTS UR PURCHASE?
3. TELL THE SPECIFICATION OF UR PC TO THE VENDOR BEFORE U BUY A NEW EXTERNAL DRIVE, AS IT MAY NOT SUPPORT SOME TIME.
4. ..... MAYN MORE...NOT COMMING TO MIND NOW... :-)
Apr 11, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
