Question about Dometic RM2652 Refrigerator
Refrig does not work on elec
Had a bad plug on elec cord supplying current to RV cord. Was cutting on and off. Replaced with new cord now will cool only on gas. Elec part does not come on. Is there a fuse or reset? Thanks for any assistance. Dometic Model RM2652
    Habit-Forming:
  • 62 Answers
There is a small fuse on some models and check you heater for a short
Posted on Jun 02, 2009
I have a Coleman mach RV roof Ac with a fan and separate Furnace unit. None of the units will turn on.The AC did work along with the fan. Now nothing works. All of the fuses are good
Check the plug end of the Power cord for a broken wire. If you can test the cord for continuity with an ohm meter do that first. Most likely you can get a replacement plug. You'll need to cut the old one off and strip the wires back to connect the new plug.
Feb 09, 2017 | Coleman Heating & Cooling
I plugged a 30 amp power supply cord from an rv to a 15 amp house outlet to run a/c to rv . gfci tripped and wont reset. damaged gfci or something else?
A GFI outlet works independently of sensing an overload condition. Overloads are dealt with by the circuit breaker or fuse in your electrical panel. The GFI simply compares the current on the hot terminal (black or red wire) with the current on the neutral terminal (white or gray wire) and interrupts the current if there is more than 5mA (0.005 Amps) difference between the two.
Remove the load - in this case the RV plug - from the GFI outlet and attempt a reset. Make sure you're pressing the RESET button and not the TEST button. If it resets - you're all set. Reconnect the RV plug to a different outlet - preferably NOT a GFI type.
If it still wont reset, it is important to know that GFI outlets can be wired in such a way that any circuit extended to other outlets (lights, too) via the LOAD terminal screws will also be protected by the GFI. We need to be sure that there wasn't something else causing the fault. Check other nearby outlets for functionality. Remove plugs from any outlet found not working and attempt to reset again.
If it will not reset - it is possible that the internal sensing circuitry has been damaged due to such a large amount of current trying to pass. In this case, replacing the GFI outlet will be needed.
Oct 09, 2015 | Washing Machines
The Target wet saw TA10100 is shutting down immediately after starting up. Anyone know the part that is causing this. We have replaced the off/on switch and repaired a wire to the switch with new conn
check where your power cord goes inside the saw to the motor. All that wrapping the cord around to pack it up sometimes works it loose. Other wise id take it to a elec motor shop for a new motor, Last one i got i think it was $40 installed. Targets arent' cheap so its worth just putting a new elec motor in it.
Oct 27, 2014 | Saws
I HAVE MY RV AC PLUGGED DIRECTLY IN A110 LONG EXTENSION CORD.....COMPRESSOR RUNS COLD 20 SECONDS THEN FAN ONLY 20 SECONDS THE COMPRESSOR BACK ON 20 SECONDS THIS REPEATS IT SELF OVER AND OVER IS THIS A...
Susan, I really couldn't tell how long the extension cord you're using is or the gauge wire of the cord. I suspect it was a type-O. In any event, for an A/C unit the gauge wire of the extension cord should be no smaller than a 12 gauge and should have a grounding plug. The length shouldn't be more 10 to 12' . Any longer and you may have some voltage loss, when the compressor kicks in (surges) to start cooling.
Hope this helped to answer your question.
Apr 19, 2011 | Dometic Rooftop RV Air Conditioner
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
Fridge acts like compressor is not coming on - Maytag wide by side - seven yrs. old
Pull the refrig out and remove the back panel . You should see the compressor and the cooling fan ( condenser fan ) . If the fan isn't working , it needs to be replaced . If the compressor isn't running or starts then cuts off , then the box plugged onto the side of the compressor , with 3 wires going to it ( overload/relay ) needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The power supply to our whirlpool american fridge feezer is still there but the fridge freezer is not working, no lights are coming on the freezer is defrosting and the water dispenser has stopped working,...
Check the circuit breakers , or , use an extension cord to a plug that you know is working ( extension cord is for test purposes only ) . Or , unplug refrig , and plug in a small lamp etc to check refrig plug . Make sure the plug is not a G F I plug .
Oct 10, 2009 | Refrigerators
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Dometic RM2652 Refrigerator Logo
339 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
