Question about Dell Dimension 3100 PC Desktop
Monitor constantly goes dim, backlight comes on and can't see anything.
Monitor constantly goes dim and can't see anything clear. How do i resolve this?
  • Hank May 11, 2010
    What type of monitor is it? LCD, CRT ?
    Problem Solver:
  • 9 Answers
Change the refresh rate of the monitor. Use the degausse button which is provided by vendor
Posted on Jun 02, 2009
Screen doesn't want to come on, then goes dim
The problem is caused by one of the inverter transformers, or one of the backlights behind the LCD screen is going.
Jun 02, 2012 | LG 22" FLATRON LCD Monitor
On switch on monitor comes on and immediately goes off.\r\nLED turns orange . No picture VarghesePaul Kuwait
In this particular issue it could be backlight. Did you try to look closely to screen and seen a very dim but there's a reflection of picture on screen.If you could able to repair electronics equipment you should replace it with brand new CCFL with the right size. If you're not able to see anything and it's blank probably your monitor has inverter problem. Test all capacitors on boards it could be bloated already.
Sep 21, 2011 | NEC LCD2190UXP Monitor
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
May 20, 2010 | Toshiba Satellite 15" Flat Panel LCD...
Viewsonis 23" lcd monitor comes on then goes dim
sounds like bad video driver or card. boot in to vga mode or even try safe mode by pressing f8 constantly on restart. if this works it is only driver. if you cant see anything on monitor after booting in safe or vga mode it is bad video card
Nov 27, 2009 | Office Equipment & Supplies
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Aug 19, 2009 | Star Logic 17" LCD Monitor
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
I have a HP Pavilion laptop ze4900. Every time I move th screen, the display either goes off completely, or it goes vey dim and I cannot read anything from it. The only thing I can do to get a display
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Computers & Internet
Monitor Problems
Defective CCFL backlight may has the following symptom:
Mar 30, 2009 | Dell Inspiron 9300 Notebook
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5315 Notebook
Dell Dimension 3100 PC Desktop Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
