SOURCE: Smoke came out of the steering column near the
sounds like you got some wires shotring, did they check wiring? remove column panels and inspect wire contacts, plugs and harness for signs of scorchining or arcing or burnt insulation, repair as nessasery
SOURCE: puffs of smoke coming out of the steering column
the problem is your signal light switch circuit board is worn out. Ive replaced that same part cause i was having the same problem. Then i had to replace my steering column for other reasons and now guess what .......MORE SMOKE!.
