Question about Toshiba TP55H60 55" Rear Projection Television
Need to install a power cord
I have a toshiba theater view tp55h60 the power cord is gone ther is a small three prong male plug on the board how do i wire it
    Problem Solver:
  • 12 Answers
It should only be 2 wires
Posted on May 04, 2010
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
Jul 01, 2011 | Philips 42PFL5332D 42 in. LCD Television
I have a 3 prung male plug, and a 4 prung female plug. Can I switch the 3 male plug to a 4 male plug?
Hi, and yes you can, its done all of the time. You want to change the plug on the wall, not the cord. That is the way it is done. Very simple. Turn off breaker to the 4- prong. Go to any hardware store such as home depot and get the 3 prong 220 volt female plug, both are the same volts, just made for different cords is all. The male is on the cord. On the 4 prong female plug thats on the wall, just loosen all 4 screws. 2- wires are hot, either black in color, a black with a piece of white tape on it is the neutral, and a bare ground which is much smaller. When installing the 3 prong female, you will use all 4 wire to. 2- hot, ! neutral, and a screw for the small bare ground. There will be a drawing on how to connect the wires with the new plug if you are not sure. Normally, there are 3 black wires, 2 hot , 1 neutral. Some times there may be 2 blacks and 1 red. A black and red will be hot.I am sure they will all be black. The plug is marked on it. It will have L-1, L-2, N, and Ground. When you remove the 4 prong female, it will be marked the same. Be sure the power is off! L-1 and L-2 are hot, and the 3rd is N or neutral. Then the small ground. Very, very, simple to change and to know which is which. The terminals on the plug are colored also. The 2 that are copper colored are for the hot wires. The brass or silver is the neutral. And you will see the ground screw. I hope I haven't confused you, it is very easy. Just when removing the wires to the old plug on the wall, which should be a 4-prong female, the 2 wires on the right and left side of the plug are going to be the 2 hot wires. The other large black is the neutral goes to top or bottom, its marked like I said with a N. and a small bare ground. Always change the plug on the wall to fit the dryer from 3 to 4, or 4 to 3. They are both 30 amp plugs, 220 volt. Very easy, you can do this!! Please rate me on my help to you.
Sincerely,
Shastalaker7
Jan 04, 2011 | Whirlpool LEB6300 Electric Dryer
The cord is gone only three little prongs there now
A standard computer cord or monitor cord should work for your set.
Aug 20, 2010 | Toshiba TP55H60 55" Rear Projection...
I was given the dryer, and the cord unattached. I want to be sure I attach them correctly. The cord has three prongs and ther are three holes for attachment. Where should the grounding be atached?
For a 3-pronged cord, the ground (nuetral) is the middle wire on the cord and is attached to the middle terminal post. the outside wires are attached to the outside posts. It doesn't matter which wire goes to which side.
On 4-pronged cords, there is a fourth green wire that is attached the unit's case for grounding purposes. Which cord you use is dictated by what power outlet you have, 3 or 4-pronged.
If I can help anymore, please let me know.
Best, G
Aug 03, 2010 | Whirlpool Dryers
I have a Toshiba Theater View and the power cord came out from the back of the televison. I can't find the location to put it back on. Could I get a diagram please?
hello if you take the back off look on the power supply board you should see a plastic whites clip with 2 pins coming off it or possible 3 just push it back in .
it will be at the top of the power supply board i hope it helps
regards
shaun
Jul 26, 2010 | Toshiba TP55H60 55" Rear Projection...
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
One of the 3 Male Jack Prongs is broken off.
This will likely require some soldering, if you are referring to the jack on the dc converter (black box) you should exercise care when opening these there coiuld be hazardous electricity in it even if unplugged. (if it can be opened, many are permanantly glued shut) you can order replacements on ebay relatively cheap, usually $15-30.
Jan 21, 2009 | Toshiba Satellite A45-S151 Notebook
I have a Hoover Windtunnel 2 upright vvacum cleaner. During regular use my wife turned it on and it staarted cleaning, then all of a sudden it stopped and then started again then stopped for good. I...
It sounds to me like the power cord has a short. To test your power cord you need a multimeter. Test continuity threw the power cord, from the male plug prongs, to the wiring inside the vacuum. You should get continuity from one prong on the male plug to only one wire on the other end of the power cord. If you test one prong but get a readying on 2 wires, then it is crossed. If you dont get any continuity on one or more of the wires, you have a short. A common place for a short in the cord is the male plug, you can find a replacement male plug at a hardware store and cut off the old one. When wiring the male plug, black wire goes to the gold post, white wire goes to silver, and green wire goes to the green post.
If your carbon brushes on the motor are warn, then that could cause the motor to stop, but other parts of the vacuum should still work so I dont think it is that.
Hope this helps.
Jun 27, 2008 | Vacuums
Toshiba TP55H60 55" Rear Projection Television Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
