Question about Kenwood XD-A55 CD Shelf System
Toshiba SD-3980 DVD player not working
The trays opens and after the disc is loaded it spins for a while and then shows 'no disc' or 'error'. Can this be fixed?
  • 822 Answers
Check and clean dvd lens. change lens if same problem.
Posted on Jun 02, 2009
I have a Toshiba SD-3980 DVD player, how can i get a disc that is in the player (which no longer works)out?
If you don't care about the unit take out all the screws on the case until you can remove the whole top, you should be able to access the disk once you remove the case.
Apr 30, 2014 | Toshiba SD-3980 DVD Player
After I insert the disc, the digital readout say bAd and the screen states Incorrect Disc.
There is an recall from Toshiba for "bad" problem in Toshiba SD-3980 dvd player.
"Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit. If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit."
Click Toshiba Support link for original message, please contact Toshiba and above number for replacement unit.
Hope these info will help you.
Thanks.
Feb 12, 2011 | Toshiba SD-3980 DVD Player
Tray Will Not Open To Load
Sound like the belt has broken on it from the gear that opens to motor that opens the tray.
Aug 11, 2009 | Toshiba SD-3980 DVD Player
Toshiba SD-6000 dvd player tray will not open. The OPEN and LOAD lights just keep flashing.....is there a way i can reset it by unplugging it? it was working fine until now.
The tray is blocked or the drive motor is stucked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check the motor if it's trying to spin. if not, disconnect it and connect it to a 12-volt supply or lower. If it spins then there's a problem with it's supply. Otherwise the motor should be replaced.
Aug 06, 2009 | Toshiba SD-6000
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-K850 trouble
I contact Toshiba Service and they suggest to unplugg AC cord then wait for 3 minutes but this is not a real solution ("Bad" message). I already notice other Toshiba models have the same problems (SD-K750 & SD-3980), and they are replaced them because of component part failure. (my DVD is a SD-K850).
They also explain that if that process not work, I must call their
Service Dept. for more details, same phone # (1-800-631-3811).
Luck!
Oct 21, 2007 | Toshiba SD-K850
Trouble with the disk tray
clean the tray, or replace the belt open the cover of your dvd
Jan 19, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Kenwood XD-A55 CD Shelf System Logo
100 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
