Battery is good but Laptop does not work on battery
Battery check showing Good, but can not work with battery, when I remove the power, laptop shut down, do not work with battery, although battery is showing 51% remaining but not charging any more.
    Problem Solver:
  • 10 Answers
MOSFET have been fixed to off state because controller had been detected bad battery.
connect a wire between MOSFET and try again.
for example IBM R32 positive side connector to MOSFET.
I have been just replace two bad cells and connect(soldering) a wire.
becareful there is not protection anymore.
good luck
Posted on Jan 31, 2010
  • 3 Answers
Some time its happen the the battry is showing full bt its discharge, that was a similar proble which i faced with my laptop, please get the battry replaced and give me the update that will all be good....
Posted on Jun 02, 2009
  • 822 Answers
Check charger IC and battery.
No power from battery or power cable
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 28, 2009 | Dell Latitude D510 Notebook
My hp ez4400 starts up but quickly shuts down ,
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Computers & Internet
System will not boot screen will not light up shuts off randomly then powers on will not charge
Dec 22, 2009 | HP Pavilion dv9205us Notebook
While using my laptop it just shut down
Dec 14, 2009 | HP Pavilion dv6000z Notebook
Power up issue
Nov 20, 2009 | Acer Computers & Internet
Hi My Dell M1530 doesn't start up The battery is fully charged, the power cord is working good(the light is on) but the laptop doesn' give a sign that is connected to power
Nov 18, 2009 | Dell XPS M1530 Laptop
I have dell PP22L when i insert the power adapter the power led of charger is shut off. no power in laptop and i did change the power still same problem. can anyone help me pls. raymond cunanan here thanks...
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 07, 2009 | Dell Latitude L400 Notebook
Hello sir i have gateway model md2614u .when i charge my battry and when it aharged full screen seen black but it shows power by red ight and it give no response.
Oct 29, 2009 | Gateway MD2614u Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Power up
i think urs battery get damaged....
but before replacing it first remove it safely n again fix it on laptop....
then restart ur laptop if same problem is coming...than it is sure dat ur battery get damaged or its efficiency get lower....
send me feed back if ur facin more problems wid ur laptop at shriii2@rediffmail.com
Jun 13, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
