Question about Metz 60CT-1 Flash
NiCad battery not charging
I have a NiCad battery for the Mez 60 CT-1 power pack, the pack has not been used for some time. I've tried charging it but nothing happens.
I've follow the instruction for charging, but when I plug it in there is no lights (red or green) and nothing seams to be happening.
  • andrea wystrach Nov 20, 2007
    battery wont hold charge and now i am thinking maybe it is the charger. where can i buy another casing and battery?
The charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Posted on Apr 24, 2009
  • mikejkahn
    mikejkahn Sep 11, 2012
    not helpful. you mut desolder the fuse holder and then figure out what type of fuse material to solder across the terminals. ideas welcome
  • 216 Answers
I believes that the 60ct-1 and 60ct-4 uses the same battery.
They do not use NiCad.
Posted on Dec 30, 2007
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Extending the battery life?
You have a Motorola CP-680, so that's the Make/Model of the radio.
You haven't informed me as to the type of battery you have powering the set. Is it a battery pack?, is it battery cells and if so what type of cells....AA or AAA? or whether it's a rechargeable type, i.e,. Nicad, Lithium, NMh, this info is required so we can quickly provide the answer, Having said all that, I'll do something I don't like doing, and take a guess....
Because it's a GP series radio, It may in fact be a battery pack, therefore it will either be NiCad or Li-ion. That being the case, you must have a battery charger that came with your radio. If you have a NiCad battery Pack, that is the culprit, as these batteries retain memory between each charge, and unless you completely drain all power from them, before recharging, you will not be getting a fully charged battery, as these will only top up the charge from the previous charge, if you follow my drift.
Better to buy Li-ion battery pack specific to your radio, as these don't have a memory issue, these are available on ebay for a reasonable price.
I hope you've understood my explanation, and that my advice has been useful.
Aug 05, 2012 | Motorola GP680 Battery
My dear friend,
If you want to repair your old nicd and want to make them work like the new ones then of course there is a solution to all your nicad battery related problems. You don't have to buy new ones because you can repair it at home. There is this very nice and efficient Nicad Battery Repair Guide through which you can recharge the old Nicad batteries within no time. With the help of Nicad battery repair manual, you can recharge the old batteries using basic home tools. I tried it myself and now I never buy new Nicad batteries anymore!
May 18, 2011 | Ingersoll Rand 14.4v Nicad Battery For Ir...
Can I use the ryobi P110 charger with the P103 lithium-ion batteries ? Thank You
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Dec 27, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
I have a Roomba, it runs for a few minutes and stops, the battery is fully charged. Any ideas?
The battery isn't able to fully charge, it just retains the proper voltage, but lacks the amperage to run because the first and last battery in the pack are dead. Battery replacement time. Try Ebay for best battery pricing.
BTW I use the nicad pack.
Mar 04, 2010 | iRobot Roomba 560 Robotic Vacuum
Eclipse Hitec 7 will not stop biip when turned on, battery has been charged for 24 hours, it still say low bat on display
Depending on the are and number of charges, the battery is dead. A NiCad battery is only good for about 400 charges. After that, it starts to go downhill. A NiCad battery will also take a memory. If it has the capacity to run for an hour but you only use it for 15 minutes, it will taka on a shorter than 1 hour memory. In time, it will only give you 15 minutes of use, even with a full charge.
Try TOTALLY draining it a few times and then charge it overnight. Do this at least 4 times. This is called reguvenating. About half of the time, it will increase the life of the battery.
Aug 04, 2009 | Eclipse Hitec 7 Fm Computer Aircraft/heli...
18 volt ryobi batteries wont hold charge
NiCads stop taking a charge because microscopic crystals build between the individual battery cells (inside the pack) and the leads between them. here is what i have done for my craftsmen NiCad 18 volt batteries to get them to once again hold a charge:
you'll need ~2 to 3 times the voltage that you are using. for instance, if you've got a 14v drill battery that has stopped working, then you'll need 28-42 volts, 18v will need 36-54 volts. i have found 3 car (or motorcycle or lawn tractor) batteries work fine. so i have 2 motorcycle batteries and 1 tractor battery.
i hook these car/motorcycle/tractor batteries up in series. positive from one batt to the negative of the next and so on until i have one positive lead not connected and one negative lead not connected.
something like this: --(batt)+_--(batt)+_--(batt)+
then with safety glasses on i touch the positive lead from the motorcycle battery to the positive tab of the NiCad drill battery with one hand and the negative lead of the tractor battery to the negative tab of the NiCad drill battery (at the same time) and count to 3. i remove and wait a few seconds (5-7) and repeat 2 more times.
once the last ZAP is done, place the NiCad drill battery into the charger and see if the charge light illuminates. if it does, then you have just saved a battery from the land fill and some $$ from your pocket. if it doesn't, then try to repeat it once more, but no more after that.
some word of caution. do not let the the + & - leads of the car/motorcycle/tractor batteries touch each other. that's 36 volts you've got there and will spark/explode.
also, if during the zapping of the dead NiCad battery you hear a "pop", one NiCad cell inside the battery pack has given up the ghost and now the battery is trash for sure. take it to radio shack for recycling. do NOT attempt to zap it again.
use at least 14-16 guage wire (or larger which is a smaller number) to connect the batteries in series and also to zap the NiCad drill batteries.
one final note: do NOT use this method on Lithium Ion batteries. it will not work and may cause injury!!!
good luck.
Oct 20, 2008 | Drills
Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Oct 06, 2006 | Metz 60CT-1 Flash
Metz 60CT-1 Flash Logo
953 people viewed this question
Top Metz Cameras Experts
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
