Question about Logitech Cordless Mouse
MY MX 700 OPTICAL MOUSE WONT CHARGE I PLACED IT ON THE CHARGER AND THE RED LIGHT JUST FLASHES IT HAS NEW BATTERIES AND A GOOD CONECTION WHAT DO I DO I have an MX Laser (old but outstanding!) that will not recharge ... I looked for replacing batteries, but there are no screws to open. Any suggestions?
  • 696 Answers
Hi smeker2003,
I have the same mouse and the same problem, it has been getting worse for some time. The reason they do this is the gold foil you see on the contacts corrodes away and eventually looses the ability to conduct enough electricity to charge the unit.
If yours is in the beginning stages of failing, simply cleaning the contacts and repositioning it slightly in the charging base may get it charging for now but it won't last long. Mine started having minor troubles about 1 1/2 years ago and completely stopped charging about 3 months ago.
Good news is they are standard AA rechargable batteries, so you can do what I do and simply swap the batteries with another device like phone or camera and charge them in the other device or buy a small wall charger and use it for rechaging once the unit completely stops.
As for the other comment, MX Revo and similar MX series do not have a "user serviceable" battery and as such there is no easy access to it, first try the above suggestion to clean contacts then, if it doesn't work and you have the skill to disassemble and saulder together new battery cells feel free to pry it open, it's preasure fitted but I would recommend just buying a new one as the cost barely justifies the time and expense of rebuilding it.
Chris
Posted on Jun 02, 2009
  • 822 Answers
Check your charger voltage output. replace battery same type and rechargeble.
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
I have 2 computers both with mx700 mouse and they have worked great for a few years. All of a sudden, both have stopped charging. The green light blinks to say it is charging when in the cradle but within...
I assume you are using usb socket to charge mouse. The voltage on a USB is 5volts , you may have a problem here. It may not be producing the correct voltage. Or you may have a problem with your cradle. I would suggest you see a repair person and get them to look at the USB voltage and the Mouse cradle..
Hope this helps.
Feb 18, 2011 | Logitech MX700 CORDLESS OPTICAL MOUSE...
I changed batteries and forgot how to reconnect. It is plugged in via USB, batteries are birght. I have pressed the connect button on the base. It flashes but the mouse does not work. I have pressed the...
This is from the manual for the Logitech MX700 cordless optical mouse.
1. Press connect button on Base Station.
Its LED blinks green. 2. Press connect
button on mouse bottom. Base Station LED
turns solid green, and then off.
I hope this helps
Mar 07, 2010 | Logitech MX 700 Mouse
My GE mouse doesn't work anymore
First thing to do is check the device manager. If it shows up there, make sure that there are no icons saying there is a problem.
Jul 29, 2017 | GE JASHO97985 Mouse
Stopped recharging
Two things: 1) This mouse and charger does not like rechargeables larger than 1800mAH. The light on the front will(sometimes) go red if you use a higher rated battery than the 1800mAH. You said you replaced the batteries, but might want to check their rating. 2) My mouse gets harder and harder to get a good connection when putting it in the cradle. Might be the contacts are getting dirty. When you put it in the charger, you should see the optical beam (red on the back) go out and the green light on the front turn on. If this doesn't happen, it isn't connected.
You do have the cradle plugged in and the batteries installed the right direction in the mouse? I know it's obvious, but the questions always have to be asked.
Aug 05, 2008 | Logitech MX 700 Mouse
Flahsing Red Light
Now what you have to do is look for a reset button on your mouse and your wireless mouse signal receiver.
When the receiver and mouse both are on press the reset button on both of them one by one.
This should solve the problem.
Jul 16, 2008 | Logitech MX 700 Mouse
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Flashing light
cycle the batteries in a external charger a fex times (charge then discharge) I suspect that over the years of using then putting it in its dock the batteries have had a very erratic charge discharge cycle cycling them as I suggest should bring them back.
Jul 25, 2007 | Logitech MX 700 Mouse
Logitech Cordless Mouse Logo
386 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
