Question about Garden
Weedeater PE 550 won't start it made a loud boom, started coughing, then died out... I thought it might be the spark plug. Therefore i replaced it this spring...It doesn't start even with the new spark plug and gas...Any tips on what might be the problem????
  • fjkhan24 Jun 02, 2009
    No smoke
    Very llittle smoke, about 3 seconds or so...
    President:
  • 1,902 Answers
Did it start smoking alot after the big boom?
Posted on Jun 02, 2009
The fb 25 weedeater has fired off a time or 2 one time it started but died like 2 seconds and only fired one more time with25 pulles
Put a little in the cylinder via the spark plug hole and see it will run a second or two. If it does then your carburetor needs repairs or replacing.
Most shops will not even accept these cheap unit in for repairs.
Mar 14, 2015 | Weedeater Garden
Craftsman weedeater will not start
remove the spark plug , an go in dark area, pull start , do you see sparks , or just grab the plug an pull it, does it hurt.(ground one side of hand to the metal so it don't course thorough ur body.
so you have spark or not ,
no ,then theres the answer magneto is shot.
yes, then take off the filter an give it some gass or just spray a bit in cyl as you put the plug back from testing the spark.
does it cough or run when gas is added into some port
no then the cyl is cracked or needs oiled , spray some oil an gas in the head w/spark removed, let it set .
May 07, 2014 | Garden
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
1997 Dodge Dakota Sport, V6. Truck died while driving and won't start.
You need to know if it is getting spark to the plugs and fuel pressure before you start replacing parts.
It could be as simple as the ASD relay.
Apr 24, 2013 | Dodge Cars & Trucks
My KLX 150s Coughing/ Dying when under the rain.
Sounds like coil or plug wire is getting wet. Could also be ignition system also. Check everything and try spraying the wires with silicone spray to water proof it.
Jan 17, 2013 | Motorcycles
Weedeater ght 180 wont start
You'll probably need to remove the carb and clean it out. Sounds like the fuel passages may be clogged.
Oct 05, 2012 | Weedeater Gas Powered Hedgetrimmer...
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
My weedeater has no spark at all
If there is no spark then I would suggest checking out the plug wire for cracks or breaks If there is none present then the ignition coil could be finished Take it off take it into your small engines dealer and get him to test it.
Dec 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Garden Logo
418 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
