Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Numerous white spots on Smasung DLP TV
White spots are just emerging on my 50 inch Samsung DLP TV everyday. It started with one two days ago and now there are almost 30, I gueww in two weeks the sreen would be covered. Help Our problem is with the Samsung DLP 50 inch model. One white dot/pixel appeared on May 21,2009 and as of June 02, we have 22 white dots/pixels and 3 black dots/pixels. Our unit is 26 months according to serial number manufacturer information. I have contacted Samsung 800 customer service several times in the last week and have received statements that they know nothing of this problem with these units. Samsung's is supposed to have the best TVs on the market and according to their own statistics have sold the most TVs in the US for the last 9 quarters going back to 2007. For a company who is avoiding correcting a problem experienced by so many customers, what does the future hold? I believe our best bet is to educate other consumers as to these practices, boycott Samsung products and move forward with a class action lawsuit. Shame on Samsung!!!!!!!!!!!
Mine is having the same problem. It started around Memorial Day and is only getting worse. One white dot is now a dozen. I called Samsung several times and was given the brush off. They clearly know this is a problem and are failing to respond to the problem in hopes that people will deal with it on their own. It does not matter if your warranty is expired. This is a latent product defect. They are still liable and obligated to fix the problem. I have filed a complaint with the better business bureau. If the company does not respond, I'm taking this to small claims court to get reimbursed for any cost to fix my tv.
Posted on Jun 30, 2009
    Genius:
  • 1,139 Answers
Hello, I have posted this eariler, it applies here so here goes: As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 12, 2009
  • Henry McKelvey
    Henry McKelvey Jun 12, 2009
    The problem is that this technology is relatively new and the components are fragile. Samsung is at fault but they themselves did not realize the failure were going to be this pronounced. Your best bet is to get the DMD DLP chip or module changed, by a qualified TV technician. I know this is not a cheap solution to your problem, but changing the DMD DLP module or chip is your only choice if you plan on keeping this TV set.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
SOURCE:
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
the dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
White spots are just emerging on my 46inch
There seems to be an issue with your DMD board, which is the on in charge of the pixelation. What you can do to confirm if it's indeed the DMD board, is the following: GO to the menu on the TV and if the dots show in the menu, it's your DMD board, but if they don't the issue might be with one of your Video Boards.
Dec 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
the problem is in the DMD Board is it something like this?
usually this happens to Samsung DLP...
here is a link where you can find a DMD Board Good luck
you will need your part number
http://www.discount-merchant.com/SearchResults.asp?Search=dmd
Aug 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
Feb 26, 2009 | Samsung HLS4676S Television
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
BAD LIGHT ENGINE call UED 1-800-648-6657
Feb 15, 2009 | Samsung HL-S4266W 42" HDTV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
779 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
