Question about XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic Card
As mentioned The other day i moved my tower to clean the table it sits on, and caught the wire from the monitor on something. Stupidly the card wasn't screwed in so it came off the motherboard a little and now when i boot the pc it makes 3 loud beeps then reboots over and again, please help.
  • 52 Answers
Card is cracked. Get a new card i'm afraid!
Posted on Jun 02, 2009
I placed my Camera's card placed In Computer and all the colors went wild, removed Card, now everthing on my screen shows mixed colorsrd
I had something similar happen to ma about a year ago, I moved my tower a couple inches to reach for something that fell and then my screen was "colorful". Turned out that I just knocked my monitors cable out just enough that it was not working properly. I would first check to see if either end of the monitor cable has come loose from the computer tower or the monitor itself.
I have also had the colors go wild when I had a faulty video graphics card, but I would start with the cable first to make sure it is secure.
Mar 05, 2014 | E-Machines eMachines T3830 PC Desktop
Balance monitor all color flushes and flashes with pic host link
Sounds like the lcd on your monitor is bad. This link shows how to replace one: http://www.fonerbooks.com/laptop_4.htm The link shows a laptop, but it's pretty much the same as with your monitor. The hard part is finding a replacement lcd to put in there. My advice would be to buy a new monitor.
Aug 29, 2007 | Balance CM2017 17" Monitor
Monitor HPw1907, screen has vertical lines, after checking monitor and cables, screen went back to blue, I have tried all the fix its, cleaning tower, which is a slimline HP 2 yrs old, out of warranty 20...
It would be the one that the monitor cable is attached to. You could try unplugging pc pop card out after taking out the one screw that holds it in place clean contacts with achohol and reseat there is a good chance that the card has malfunctioned but you should also see if you could take the monitor to a freinds house or another pc in the house see if you get dame results. That way at least you can count that out.
May 06, 2011 | HP w1907 LCD Monitor
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
Ultrasharp 1800fp monitor will not turn on
MY MONITOR DOES NOT TURN ON AT ALL.
WHAT SHOULD I DO???
Apr 12, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Hello today I had an white vertical line in the center of my PC screen Gateway E2500s series would not shut down from the tower so IV turned it off with the surge and waited a few them turned it back on...
You mention in your post to branded laptops. You can try to check if the problem is from the LCD or from the Video card. Connect your laptop to an external monitor and check if the white vertical line appears, if yes replace motherboard if video card is integrated, if expansion then replace video card alone. If no lines from the external monitor then laptop LCD has the problem.
Oct 03, 2009 | Dell Latitude D505 Notebook
Moniter is only shows self test e173fpc
It sounds like your video card may be kaput. Can you try another monitor on it? If you use a monitor that you know works, and it does the same thing - then your video card has failed.
Alternately, you can try a different card and the same monitor.
Jun 08, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor or pcu problem
It appears that your graphics card is defective. If the monitor works on your laptop and reinserting the graphics card did not help, I would suspect the card itself.
Aug 19, 2008 | Acer AL1716 17" LCD Monitor
XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic Card Logo
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
