The ringer is not working
SOURCE: I have a vodavi phone system and am trying to turn
Break into admin section of voicemail, go to system greetings, select greeting you wish to change. Need more info, email. If this is helpful, please post as such
SOURCE: How do you get a Vodavi xts phone to ring for an outside line
You're probably looking in the EXTENSION USER'S GUIDE. The sytsem installation/programming manual has the proper FLASH codes and programming access to make it work.
As far as the random calling, try changing phones with another and see if the problem stays with the set or the location. If it's set, you have a bad one, if location, I'd be looking at a wiring error.
Carl
SOURCE: Our church has a vodavi starplus sts phone system.
You must go into CO line programming and put that station into the ring assignments for each outside line you want to ring at that station. It's Flash 40, page A, button 10.
SOURCE: Can't access Vodavi STS Starplus voicemail to program it
THE VOICEMAIL OF OUR PHONE SYSTEM IS NOT WORKING RIGHT...
SOURCE: On a Vodavi STS Starplus
Sure. Restrictions are governed by the station Class of Service. COS6 is intercom only, or you can build tables and give a station some calling capabilities. There's also a traveling class of service and verified account codes to override your restrictions for users with a proper code.
COS descriptions are on pdf page 85 of the STSe manual http://www.wedophones.com/Manuals/Vodavi/Vodavi%20Starplus-STS/STARPLUS%20STSe%20Programming%20and%20Operations%20Manual.pdf
Carl
