Question about Intel Motherboard
Nic keeps saying cable is unplugged - Intel Motherboard
  • Anonymous Dec 08, 2007
    I have the same probem. Running XP and have a router which is working fine.
  • animosity Jul 09, 2008
    Same OS same problem I have another computer on the same router and works fine, but my system only brings up Cable Unplugged. I have tried another cable, bypassing router, and all other hardware-related fixes I could think of.
  • 55 Answers
You need to have a valid router/connection on the other side of the cable - do you?
Posted on Oct 23, 2007
SOURCE:
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
Hiro h50015 nic on windows 7 says network cable unplugged when cable is clearly plugged in
To connect to the internet, you must have a device like a modem or a router. Is your PC connected to this device? Do you have other PCs or networked devices on your LAN? Can you reach them with ping?
To make it easier to help, you should give information how your network looks! e.g.
internet ---- cisco800 router --- d-Link switch ---- myPC
or something like that. Otherwise it is fooling around in the dark.
Apr 13, 2014 | Hiro H50015 Network Adapter
Just will not let me log on to the internet keeps saying cable is disconnecte
either your cable is bad or your nic is bad.
If its the cable use a different one and remember pc to modem needs a "patch" cable.
Oct 28, 2009 | Compaq Armada M700 Notebook
Fixable problem or motherboard going out?
Make sure that modem port is working. Check modem on other PC.
Use different LAN cable.
I suspect NIC failre... you can installa addtional a PCI Ethernet Card and disable integrated NIC.
Oct 20, 2009 | ASUS P4V8X-MX Motherboard
I have a new Netgear DG834(wired)from which I run my main PC & my daughters laptop & desktop PC's, one of the upstairs PC's suddenly cannot connect to the internet , the connection status icon in...
Hi more likely it seems to be an issue with the Ethernet card on the concerned computer. If you have a cross over cable then please connect that computer to another laptop and check if it still shows the error msg or shows connected. Let me know if you need any other help.
Sep 05, 2009 | NetGear DG834G Router
Kyocera 3035 will not print - NIC card red LED flashing
First turn the main Power Switch off, then unplug the network cable from the nic card and leave it unplugged. Then turn the machine back on, when it says ready to copy, press the printer button and print out a network status page. Then hook the network cable back up and go to a pc and click on start then control panel and look for printers and faxes and click on it, then right click on the Kyocera Printer Icon, then click on properties in the drop down then click on the port tab, then click on configure port and check the ip address and make sure it matches the one on the network status page, if it doesn't put in the correct IP Address and apply the change. But if the ip address is right just try printing again. If it prints ok then you are done but if it doesn't try this click on start then run and then type in cmd, then on the screen that opens up type in ping, then a space, then ip address of the Kyocera Machine then press enter, if the Nic card is connecting to the network you should get a reply from the Kyocera's Nic Card if you do then the Nic Card is ok and the Kyocera print driver may have to be deleted and then re-installed. Hope this helps.
Aug 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Dell E6400 onboard NIC cannot get network connection - "A Cable Is Unplugged". The laptop is undocked with CAT5 cable firmly attached.
I'd suggest updating the NIC driver in Device Manager. But, the message "A Cable is Unplugged" tells me that the NIC port, the CAT5, or the port where is is connected to your modem/router may be faulty. Try moving the cable to a different port on your modem/router, first. Then, try another CAT5. If still a problem, the NIC port is probably faulty. Hope this helps.
Jul 22, 2009 | Dell Latitude E6400 Laptop
Pc's say a network cable is unplugged
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
Also,
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Happy Holdiays!
Dec 22, 2007 | HP ProCurve 408 Networking Switch
Linksys LNE100T x ver 2
instal the driver for the NIC card
Oct 19, 2007 | Dell (063MY) Network Adapter
Intel Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
