Question about Rinnai RER-55AS 55-Cup Rice Cooker
Will not turn off
Unit will not turn off when it should the flame keeps burning also where can i find a parts brake down on thi unit
  • Rinnai Master
  • 3,328 Answers
There is a parts list on the wed , there should be a temp sensor inside that shuts the gas off when its finished cooking , it might be cheaper just to buy a new one ?
Posted on Dec 08, 2008
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
Kerosene Heater starts up and then shuts down
David, you need a copy of the Troubleshooting Manual here:
http://www.toyotomiusa.com/OwnersManuals/Portable%20Heaters/Name%20begins%20with%20LR%20or%20LS/LR-350%20LR-450%20Troubleshooting%20manual.pdf
It sure sounds like a failure during pre-ignition. Page 5 covers both of your burn times with two different Flow charts.
A yellowish flame can mean a warped flame ring or incorrect air flow.
Dec 29, 2014 | Heating & Cooling
My adp cuhn-60a-2 sparks an lights burner ok, burns for only few seconds an shuts down burner, repeats this three times an whole unit shuts down?
You are describing the typical issue for a problem in the 'flame rectification' circuit. Turn the powere off. Find the flame sensor, it will be on the opposite side of the furnace from the spark ignition device. Carefully remove the sensor and clean with fine sandpaper, then clean the wire connector on the end of it if so equipped, then follow that wire all the way to the circuit board, remove the wire connection and clean it and reinstall. Many times that solves the issue.
Some systems utilize the spark ignition electrode as its own flame sensor. IF there is no separate flame sensor, perform the above task on the ignition device instead. Be careful NOT to bend the probe, crack the ceramic insulator or reinstall it malaligned. Its location in the pilot flame is critical. Slight relocation by improper handling will render it unable to ignite the pilot gas.
There may be another issue as there are many things that cause ignition lockout, but this is the first thing to do to eliminate the situation you've described.
If you are unsure of performing this and ANY minor maintenance to a gas fired appliance, abandon the idea and call a qualified service tech to proceed.
R150B kerosene reddy heater, every 2 to 3 seconds It has spurts of flame, why?
generally water or air in the line will interrupt the flame momentarily.
Nov 25, 2014 | Reddy Heating & Cooling
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
New blue flame heater, everything is hooked up, gas is going to unit, I have a natural gas hookup, in the correct port, knob is turned and locked into the NG position but unit wont light. There is gas...
do you have the pilot light burning if not then you have to get in burning first
Put knob in pilot position push down and hold for at least 30 seconds or longer then if there is an igniter push and release it push and release till pilot light comes on .Continue to hold pilot light button down for another 10 seconds or so, release pilot button and turn button to on or up a number or set T stat
Main flame should come on and burn
Oct 13, 2013 | Procom Heating & Cooling
Lgdle2532w dryer keep turning off run for about 15 second than stop running. thies a burning smell to.
Obviously the motor stays in the "start" mode. That is most likely due to a stuck starting switch, which is part of the motor.
May 08, 2011 | Dryers
My RGDG-100AUER will keep a pilot flame for one burn cycle. When what I think is the beginning of the next burn, I hear a click, and the flame goes out. If I hold the pilot stud down, relight it, the...
Check the flame sensor is clean . or pilot may be blocked .Too short and the main gas is taking the flame away so it goes out , Also check thermocouple .
Oct 10, 2017 | Heating & Cooling
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Rinnai RER-55AS 55-Cup Rice Cooker Logo
131 people viewed this question
Top Rinnai Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Rinnai Kitchen Appliances - Other Expert? Answer questions, earn points and help others
