Question about Brother MFC-8840D All-In-One Laser Printer
Printing 100 to 200 extra sheets of paper
About once or twice every week when someone in our office prints just one piece of paper that one piece of paper is followed by 100 to 200 sheets of paper that read
ERROR NAME: undefined COMMAND: OPERAND STACK:
How do I quit the printer from wasting all this paper?
    President:
  • Brother Master
  • 1,447 Answers
Your machine is pogram problem
Posted on Jun 03, 2009
  • Sazeed Computer
    Sazeed Computer Jun 11, 2009
    Your printer is reset printer status
    if you are not success then you send me your address. I have MFC 8840 mother board send for you
How do I get my HP OfficeJet Pro 8725 printer to spit out the printed paper without force and an extra sheet?
Have the memory inside the printer tested. Add as much printer memory as you can to the printer to speed it up.
Mar 16, 2017 | HP OfficeJet Office Equipment & Supplies
HOW TO CLEAN STAMPS AFTER RE-INKING
I would take a sheet of printing paper and do several stamps on that piece of paper until you got a clear image of your stamp.
Feb 24, 2011 | Office Equipment & Supplies
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
CANON I960 BLINKING RED LIGHT 2TIMES
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
Getting extra 1 inch margin on ''normal'' or ''best'' print
Hi - have you checked the settings for both the document(s) you are trying to print and the defaults for the printer? It could be that there is a default setting that is trying to override what you want to do. I can't think of a reason for it to act differently with different quality of print, unless the ink is running low - that can affect a document printing or not, but again, I would not think to this effect.
Some things to check on -
- Go to the control panel, open the Printers and Faxes folder, and right click on your printer.
Choose PROPERTIES. Make sure everything is set like you want it to be.
(If you are on a network of some kind, someone else's settings could be overriding yours. If you are not on a network, make sure "Do not share this printer" is checked on the sharing tab.)
-try to update the driver. Here is a good place to look -
http://preview.tinyurl.com/6bwuk8
I am assuming you have already actually checked for little scraplettes of paper that might be stuck near a sensor or an ink cartridge. I'd even pop the ink cartridges out and put them back in. Sometimes dust can build up on them if a printer isn't used often, or has been sitting for a long time.
Also, make sure you don't have a setting on your own computer to print out a blank sheet before a printing job. If your printer is actually run through an I/T department at work, they could have it set up by default to kick out a separator sheet to help keep orders separated.
I hope one of these things might work for you! : )
Nov 20, 2008 | HP PSC 2510 All-In-One InkJet Printer
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
344 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
