Compressor does not stay on.....
Carrier UCD081B compressor does not stay on, comes on and off, but turns off before hitting the set temp..???
  • Marc Frato Jun 02, 2009
    sounds like the problem, I have it open with wires hanging out, and it's running now, but no obvious problem......... I was thinking to just replace the thermo switch, but thought I would check here first.
    President:
  • 1,902 Answers
BAd theromostat wiring in the unit itself. If you would like I can pull a manual for you.
Posted on Jun 02, 2009
  • Jeremy Reddick
    Jeremy Reddick Jun 02, 2009
    Alright, feel free to come back and ask if you need anymore help
Carrier 38CKC036 compressor will not cycle after initial run.
Does it have a low pressure switch. It sounds like it is a pressure switch issue
May 16, 2014 | Carrier 38CKC036 Air Conditioner
My carrier unit #38TKB042300 / 3794E16886 Is not cooling. The Compressor is not running. I thought maybe the capacitor might be bad so I put a new one one. The compressor comes on and runs for 3-4...
Check the running pressures and if the low side drops to low it may be shutting down on low pressure switch.I just used this as a rule of thumb. If the outside air temp is around 90 degrees then the pressures should be in the range of 60-70 on the low side.And 250-300 on the high side. If you can get the compressor to stay on then I would clean The a-coil and condensor to get maximum effiency.Thank you.
May 10, 2011 | Carrier 38CKC042 Air Conditioner
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
Fan wont turn off
the control board is bad safety feature of carrier board . Tom
Jun 29, 2009 | Carrier 38CKC042 Air Conditioner
Compressor fan cycles on and off .1986 carrier mo#38eh0363300l
Usually compressors cycle on and off due to the low preasure switch which disconects the compressor when their is a freeon leak. Put the gages on it and see if the preasures are correct.
Jun 26, 2009 | Carrier 38CKC036 Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Refrigerator Problem
Could be the temp control is not registering temps correctly. If you leave is below 6 does everything warm up? The compressor should only run when it needs to, not all the time. In other words, if you put it on 4 will the food stay cool (about 38F)? A typical unit only runs a few minutes a day if the doors are not opened up all the time.
Feb 02, 2007 | Avanti 310SST Compact Refrigerator
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
