Question about Sony Cyber-shot DSC-T100 Digital Camera
There is a strange sound coming from my camera and vibrations
Every time I turn my sony DSC T100 on it makes a low, grinding sound. I Can't imagine there are many moving parts inside so the only thing I can think of is that its the lense. If I change modes from picture taking to picture review the sound stops after a few seconds but If I go back to taking pictures it comes right back. Also, sometimes when I turn the camera on it says I need to reinsert the memory stick even though its already in there. Im sure the two problems are unrelated but both are rather bothersome problems. Any help would be great. My camera making strange and vibrating noise in ON position ?
  • Sony Master
  • 4,806 Answers
Hi there.
It sounds like the lens is having difficulty moving into position, cover the lens with your thumb and spray a little WD-40 around the affected area.
With the camera card, take it out, clean the contacts and blow down the slot to remove any dust that may have built up.
Make sure the camera is turned off while you spray it.
Good luck and thanks for choosing FixYa!!
Posted on Jun 02, 2009
HI, my sony cybershot T100 has been giving problems for a few months. Every time I take a picture, they come out blurry or moved and now even though the view in the back, images look out of focus and the ...
This is the sony support page for your camera, you may find the fix here:-
http://support.sony-europe.com/dime/digistill/cyber/cyber.aspx?site=odw_en_GB&m=DSC-T100
Sep 17, 2011 | Sony Cyber-shot DSC-T100 Digital Camera
Please please i am scared to do this. By my camera vibrates and shakes, alot.
there is a problum in LVS assy thats why your camera vibrate please go to your nearst sony service centre & fix this problum or change LVS assy
Sep 23, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
My sony cybershot DSC-T100 digital camera as fall down from my hands now it is in working position but it is vibrating like mobile phone when i am opening the shutter. So plz any one help how to solve the...
Please reset the Camera and check if that helps.
To reset the Camera, select the INITIALIZE Option from the MAIN SETTINGS 1 Menu of the Camera to OK.
If the issue still persists, power reset the Camera and check if that helps.
To power reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 15 seconds.
Then, reinsert the Battery Pack after 1 minute, then turn ON the Camera and check if that helps.
If the issue still persists even after power resetting the Camera, unfortunately the Camera requires service.
Thank You!
Apr 09, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Display vibrates powering on
i have send this link solve your this problem.
i hope you satisfied with my suggessions.
thanks.
  • Please verify that your camera is a DSC-T20 with serial number between 500001 and 525350. The model name and serial number are located on the label on the bottom of the camera.
  • Verify that your DSC-T20 camera is experiencing the vibration issue and an inability to focus and/or take pictures.
  • Sony will provide free repair only for DSC-T20 cameras within the affected serial number range that are experiencing the issues described above. All other cameras are subject to normal limited warranty terms.
If you have questions or require assistance, please call Sony customer support center at 800-784-6726.
Feb 14, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Charger for a camera
You need CHARGER, BATTERY (BC-CSGC) for DSC-T100 and its available in Sony Accessories Store with part number 148017521 for $52
Dec 28, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
Sony DSC-T100 Camera, doesn't turn on, bought new battery still doesn't power on
is there any plug for AC ? try work with AC. if nothing happens looks like mainboard.
May 31, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
The grinding sound is the gears grinding in the lens. When you turn on the camera, the lens comes out. If you hear a low grinding noise the gears could have lent, sand, dust, etc. trapped between. It can become a problem over time. When you switch modes, lens will adjust to whatever setting. Thats why you get it sometimes and not all the time. And really theres not much you can do. You can try taking it to penn camera or ritz camera and ask them to use an air compressor to try and blow out whatever is in the gears, but its not going to be a quick easy fix depending on whats trapped. Cost of fixing your camera is around $120. Sony is not a cheap company.
As far as the memory card, have you formatted it? Whenever you delete pictures, the are still on the card. So you can still recover them with the right software. Try reformatting you card. Please bare with me im not positive word for word on your menu settings. Should be under Menu --> Tools (3rd option down. The picture to the right of it looks like a memory card) And go to format. You either 1 need a new memory card or 2 just need to format it. Please make sure that you are pushing the memory card all the way in the slot. Push in until it clicks. Its spring loaded.
Mar 29, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
Blurred pictures
I had the same problem. The solution is in the manual but it is not straight forward. You have to set steady shot to auto when the shutter button is pressed half way down. The vibration warning will still show. At this point the camera is sensing low light. The to need to make sure the flash is set to always on. The flash setting for background will not turn the vibration warning off.
Dec 10, 2007 | Sony Cyber-shot DSC-T100 Digital Camera
Sony Cyber-shot  DSC-T100 Digital Camera Logo
368 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
