Question about Canon FaxPhone L75 Plain Paper Laser
Led Alarm turn on message: change the Cartridge
This FAXPhone  had a jam  and  pulled  the sheet  and then lost a "spring" (it did get out  together with the  sheet jammed).
We replaced (changed)  the  Cartridge (New)  and  in the Display  appears the same  message :  Change the Cartridge  and the  red "Led"  of  Alarm  is  turn on.
Can you send me a Schematic Diagram to find where is the position of the "spring"  or maybe you can tell me  how  "erase"  the  "alarm"  o "error"  in the FAXPhone
Thank you for your assistence
Enrique Gonzalez
enrique.gonzalez@averydennison.com
Monterrey, Mexico
Phone: (52) 81 88644100, Ext.12
Skipe: enrique.gonzalez.medina
    Scholar:
  • 159 Answers
I'm not sure which spring you mean. From what you are saying, it could be one of the springs that keeps the drum cover closed on the cartridge itself. In this case it's probably that you are using a cheap re-filled cartridge that hasn't been assembled correctly. The cover is designed with a piece that actuates the sensor which tells the machine that a cartridge is present. My suspicions are that this sensor has become misaligned and needs to be replaced. Keep looking and you will find it. Any drawings Canon provide won't show clearly enough to work with.
Posted on Dec 27, 2007
My HP Photosmart C4400 keeps giving me the message, "The cartridge cradle cannot move. Please turn device power off. Check device for a paper jam or other obstruction." Two days ago, early in...
sure
or paper scraps in side blocking key sensors or other parts
clean all that chaff out first.
blow it and brush and pluck it all out.
there is nothing simple on printers, and 10000 types.
if fails to work after all that , it needs service.
Mar 16, 2017 | HP Photosmart C4400 series
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Alarm message says "cartridge jammed". Does that
What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
blocking the path of the ink.
Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
If the alarm message continues, I suggest changing the ink cartridges.
Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
Incorrect paper size so fax was received in
That suggests a sensor is jammed or damaged... sorry I know no more.
Nov 04, 2017 | Canon FAXPHONE L170 Plain Paper Laser
"Install Cartridge" Message
remove the cartridge and see if has some band or some sticker on which should get off (see on the box of the cartridge it must write if something like that should be removed) , or just remove the cartridge and putt it carefully and it might be not set good.
Please rate the post if is it helpful for i to know do i should post some more information
Regards
Jan 12, 2010 | Canon FAXPHONE L170 Plain Paper Laser
A paper jammed and I pulled it out. Now the red light is blinking and it says clear paper jam but there is no jam. How do I get it to work again.
Remove all the paper from the recording paper tray and then turn off (count to 10 ) and on the machine. Then reload ALL the recording paper together. Also, before doing this open the printer cover and remove the cartridge to make sure there is no pieces of paper stuck inside the machine - then carry out the above procedure.
Good luck
Sep 25, 2009 | Canon FaxPhone L75 Plain Paper Laser
Alarm is flashing, LED reads install Cartridge but the cartridge is installed. Any suggestions? Yes it is the right cartridge and I have tried replacing it with a new one, same error message
You've most likely got a dirty corona wire and/or drum. The wire should be cleaned each time you change the toner as well as if/when the print quality starts to degrage. Remove the toner cartridge, give the corona wire several swipes with the tab and make sure the tab is put back securely in place. If cleaning the wire doesn't fix your problem, go ahead and clean the drum. Either one of these or both should solve your issue. Only other thing that could cause your error would be the toner cartridge is not securely in place. (shouild click in securely). Best of luck.
Jul 07, 2009 | Canon FAXPHONE L170 Plain Paper Laser
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Nov 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon faxphone B640
The ink cartridge holder was kind of wiggly, so I put a wedge in the side to push the contacts together more. It worked.
Mar 11, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon FaxPhone L75 Plain Paper Laser Logo
189 people viewed this question
old marine
old marine
