Question about VeriFone Omni 3700
Omni 3740 SYS Mode file group 1 password?
Cant start the download with omni 3740 it ask me for password and i tried every password i have nothing working
  • Ronald Erickson Nov 06, 2011
    You need the default password reset. You can order this service at CardSystemTechnologies.com
    Problem Solver:
  • 5 Answers
Where did you purchase the machine from? Or do you know what companies have downloaded onto it previously? They must have changed it at some point.
Posted on Jul 16, 2009
After a full download, we get an unzip error 4 on our omni 3750. What is causing this? We have tried multiple times with the same result. Our merchant services help desk tells us that we must buy a new...
this sometimes happen when still old files in the memory you need to edit all your files from your memory and erase everything if need more help call us @775-358-2922 : - )
Jun 20, 2011 | VeriFone Omni 3700
I'm trying to reset the Group 1 password on my Verifone Omni 3750
The password on most vx510's can be reset by pulling battery and clearing RAM. Reassemble, clear Tamper and password will reset to original password (1aa66831). But if the certificate has been changed, only your download provider can help you. Call Frank @ 775-338-6634
Jun 08, 2011 | VeriFone Omni 3700
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
I have an Omni 3750 that I bought from a provider. I have since switched providers and now my Omni 3750 reads "download needed no *go variable". My previous provider gave me several passwords...
Here's Some that you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jan 19, 2011 | VeriFone Omni 3700
3740 system mode file group 1 password
1 - a - a - 6 - 6- 8 - 3 -1
unless it's a propietary processor, that's the factory verifone password
Oct 27, 2009 | VeriFone Omni 3700
Need to reset password for verifone omni 3740
If you press the F2 and F4 buttons and enter 1 Alpha Alpha 66831 and the terminal goes back to the idle screen then the system password has been changed or the battery is bad in the unit and will have to be replaced. Either way it will have to go to a repair facility to be corrected.
Aug 12, 2009 | VeriFone Omni 3700
Verifone omni 3750 ethernet problems...
chances are you would need to RAM FILES, FLASH FILES, DEFRAG FILES....this is like resetting and crashing the terminal, starting all over again.
Try this, press F2 & F4 together you should be on GO VARIABLES, enter password 1 alpha alpha 66831 use the down arrow locate RAM FILES, CLEAR ALL GROUPS, CONFIRM, FLASH FILES, CLEAR ALL GROUPS, CONFIRM, then DEFRAG, ALL GROUPS, CONFIRM
Plug in your DSL or cable line (the one you are using) locate the DOWNLOAD, do a FULL
this should pickup your new IP address and make sure you are on COMM SERVER not on DIAL
(dial is only for analog phone line)
Nov 11, 2008 | VeriFone (M19755014US1) Magnetic Card...
Verifone omni 3740
Most likely:
1, alpha, alpha (little gray button between the four purple keys), 66831, enter
Sep 23, 2008 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
Gone into safe mode cant change mode?
1. Click Start, point to Find, and then click Files or Folders. 2. In the Named box, type msdos.sys. 3. In the Look In box, click the drive on which Windows is installed (usually drive C), and then click Find Now. 4. Right-click the Msdos.sys file, and then click Properties. 5. Click to clear the Read-Only and Hidden check boxes to remove these attributes from the Msdos.sys file, and then click OK. 6. Right-click the Msdos.sys file, and then click Open With. 7. In the Choose the program you want to use box, click WordPad, and then click OK. 8. Do one of the following: • Delete the BootSafe=1 line.
-or- • Change the value in the BootSafe=1 line to BootSafe=0. 9. On the File menu, click Save. 10. Right-click the Msdos.sys file, and then click Properties. 11. Click to select the Read-Only and Hidden check boxes to set the attributes for the file, and then click OK. 12. Restart your computer.
Apr 16, 2008 | Video Cameras
Retail Supplies Logo
793 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
