Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to rename host in win xp using netsh command
  • 634 Answers
Windows key + pause key,
click computer name,
click change.
Restart PC
there may be a better way without having to restart but I haven't found it yet. For those who do not find the pause key: it has the same effect as right click on "My Computer" and choosing properties.
Posted on Jun 02, 2009
How do i pull up "Netsh" on a toshiba laptop?
Assuming you've already confirmed that the toshiba can supported a hosted network ...
to create a hotspot, at the command prompt, type "netsh wlan set hostednetwork mode=allow ssid=yournetworkname key=yournetworkpassword," and hit Enter on your keyboard. Remember, "ssid" refers to the WiFi hotspot's name while "key" is said network's password. You can also use the aforementioned command to change the hotspot's name and password.
To get the hotspot up and running, type "netsh wlan start hostednetwork.
Mar 05, 2014 | Toshiba Computers & Internet
Can't connect to wireless router
1.Ensure ethernet cord coming from modem is plugged directly into internet port of router.
2.Powercycle equipment (Unplug power from home modem and router wait 15 seconds then plug back in
3.Open Network Connections XP:Start/Run/Type ncpa.cpl
Vista/7 Start/Search bar/Type ncpa.cpl
4. A.Right click on wireless connection the connection you use with router and hit properties,
B.Uncheck Internet Protocol Version 6/ Click on Internet Protocol Version 4 and hit properties,
C.Ensure Obtain an ipaddress automatically is checked
Ensure Obain a DNS server automatically is checked as well
5.Open Command Prompt XP:Start/Run/Type cmd
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt hit run as administrator.
6.Type in Command Prompt: netsh int ip reset reset.log (Hit Enter after each command)
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
7.Restart Computer
8.If still unable to access internet Disable Firewalls/Antivirus
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
Says it has internet connection, but won't load webpages
1. Try booting up your computer in 'safe mode with networking' and check if the web pages are loading.If so, the problem might be with the firewall on the computer.(Make sure that you have connected the laptop wired onto the modem/router before going into safe mode. You can go into 'safe mode with networking' by continuously tapping the F8 key just as soon as you press the power button)
If it does not work try this:
2. Open up command prompt (start>Run>cmd in win xp or else for vista and win 7 click Start>type in cmd in the 'start search' box and right click on cmd.exe on the top and select 'run as administrator' ;click on yes or continue in the next box )
3. type in the following commands:
Hit the Enter key after typing in each command
ipconfig /flushdns
netsh int ip reset resetlog.txt
netsh winsock reset
restart your computer. see if it works. reply if it doesn't.
Dec 09, 2010 | Toshiba Satellite L45-S7423 Notebook
Configure my linksys wrt120n with the cd but can't found the internet all wiring are okay
1.Powercycle your equipment (unplug) Modem and Router
2.To ensure it is setup correctly the Ethernet cable should be plugged into the Internet port of the router
3.Wait 15 seconds and plug equipment back in
4.Check Firewalls Win XP: Start/Control Panel/Firewall/Turn off not recommended and try the internet
5.XP: Go to Start/Run/Type ncpa.cpl this will bring you to Network Connections/Double Click on Connection ensure the it is assigned by DHCP and it has a valid ip address it should start with 192.168.
Vista/7 Go to Start/Search Bar/Type ncpa.cpl and hit enter, right click on connection and hit properties. Uncheck Internet Protocol Version 6 and Click on Internet Protocol Version 4 and hit Properties. Ensure that Obtain and ipaddress automatically is checked as well as Obtain a DNS service automatically and hit ok.
6.Restart computer and Try to get online
7.Go to command prompt Win XP:Start/Run/Type cmd and hit ok Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit run as administrator.
8.Type ipconfig /release and hit enter
Then type ipconfig /renew
9. Minimize command prompt and try browser
10. If still unable to access the internet open command prompt again and type:
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns and restart computer
Oct 02, 2010 | Linksys WRT120N Router
Router will not connect
Depending on what router or connection you are using try these steps.
Windows XP
1.Powercycle all equipment (Unplug)
2.Wait 15 seconds and plug back in.
3.Go to Start/Run/Type ncpa.cpl
4.Double click the connection you want to connect to
5.Click on tab next to General
6.Ensure that it is assigned by DHCP
7.Ensure It has a valid ip address It should start with 192.
8.Go to Command Prompt Start/Run/Type CMD and hit ok
9.Next to C: Type netsh int ip reset reset.log
netsh winsock reset
ipconfig /flushdns
10. Restart Computer
WINDOWS VISTA/WIN 7:
1.Start/Search Bar/Type ncpa.cpl
2.Right click on the Connection you want to connect to
and hit Properties
3.Uncheck Internet Protocol Version 6
4.Click on Internet Protocol Version 4 and hit Properties.
5.Ensure Obtain an IP address automatically is checked
Ensure Obtain a Dns Server automatically is checked as well
6.Exit out of everything
7.Go to Start/All programs/Accessories/Right click on Command Prompt and hit Run as Administrator then click continue.
8. Type: netsh int ip reset reset.log
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
9. Restart your computer.
10. If you are still unable to access the internet you may have a virus I would suggest running an Antivirus. I hope this Helped Good Luck
Oct 02, 2010 | Belkin Computers & Internet
Can not get connected
Powercycle (unplug power) all your equipment, Modem/Router waite 15 seconds then plug back in. If you are having an issue with the ip address not valid you can try these steps
(win xp) Start/Run/Type ncpa.cpl hit ok, You will see wireless connection double click wireless connection this will bring you to the properties. ensure that the connection is assigned by DHCP also check to see if you have a valid ip address
Win Vista/7 Start/Search Bar/Type ncpa.cpl Right click on wireless connection and hit properties. Uncheck Internet protocol version 6 and click on Internet Protocol Version 4 and hit properties/Ensure that obtain ip address automatically is checked as well as obtain dns server automatically. hit ok close out.
Go to command prompt Win XP Start/Run/Type CMD hit ok
Win Vista or 7 Start/all programs/accessories/ right click on command prompt and hit run as administrator.
At command prompt type;
netsh int ip reset reset.log hit enter
netsh int ip delete arpcache hit enter
netsh winsock reset hit enter
ip config /flushdns hit enter and restart computer this will reset the ip address hope this helps good luck
Oct 01, 2010 | Computers & Internet
I baught this belkin router at a yard sale,when I got it there was no disc to install it on my computer,I have hooked it up and it says I am connected but when I try to get on line it can't find the sever.
From what I can tell you are using Mozilla Firefox Try using Internet Explorer if ip address id not valid it will tell you Internet Explorer cannot display webpage In order to renew ip address these are the steps you will want to take:
1. Ensure the equipment is connected correctly(Ethernet cord from modem to Internet port on router
2.Open network connections Win XP:Start/Run/Type ncpa.cpl
Vista/Win 7 Start/search bar/type ncpa.cpl
3.This will bring you to your network connections window
4.If using XP: Double click on wireless connection and hit the support tab. Ensure it is assigned by DHCP and the ip address should start with 192.
5. If Vista Or Windows 7 Right click on wireless conenction and hit properties. Uncheck version Internet Protocol Version 6
6. Click and Highlight internet protocol Version 4 and hit properties
7. ensure that it shows obtain ip address and obtain a dns server automatically
8.After go to Command Prompt (Win XP) Start/Run/Type CMD
Windows7/Vista:Start Start/All Programs/Accessories/Right click on command prompt and hit run as administrator then hit continue type in these commands.
9. Restart Computer hope this helps please rate thank you
Sep 30, 2010 | Belkin (F5D5231-4) Router
How to Rename the Host using hte Netsh or CMD
DEAR SIR
plese do the following to change your hostname
right click on mycomputer>properties> (there please change the computer name ) .
regards
murali
Dec 27, 2008 | Microsoft Windows XP Professional With...
How can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
May 15, 2008 | Microsoft Windows Server Standard 2003 for...
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
142 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
