Question about RCA RCR860 Remote Control
Rca rcr860 remote manual code list
I lost my manual so i dont have the code list anymore.. and i switched tvs.. so i need tha code for toshiba tv, to pro9ram it with the rca rcr860 remote. my tv skips channels when you manually chan9e the channel so i cant watch any dvds.. cuz i cant 9et it to channel 3 it 9oes.. 2 7 8 9 11 13 56 etc... can sOmeone help me i cant find the manual for this remote anywhre.. or a codelist that actually works.. -_- wow..
  • 16 more comments
  • dragonladies Nov 25, 2007
    I have lost my manual and the remote will not turn on my T.V. anymore so i need to add a code so that it will work. Can anyone tell me the instucts to put the code in i have the codes i just don't have the instructions to put the code into the remote.
  • B_rock Nov 28, 2007
    Yes, I have misplaced my code list for the RCA RCR860 remote. Can you please give me the codes for Sansui TVs? Much appreciated.
  • Anonymous Dec 17, 2007
    owener manual
  • Anonymous Dec 19, 2007
    i lost my manual where i had the codes. so i need if you had the codes so i can activated my t.v
  • jimseal Jan 05, 2008
    Kids got hold of remote, wife threw away instructions and codes. Who needs techinal instructions when we can just buy a new one? Riiiight...
  • Anonymous Feb 21, 2008
  • Anonymous Feb 26, 2008
    remote codes for pionner tv
  • Anonymous Mar 10, 2008
    lost programming guide and codes for RCA remote
  • Anonymous Mar 21, 2008
    LOST MY UNIVERSAL REMOTE INSTRUCTIONS NEED ASISTANCE PLEASE!
  • Blu1 Apr 04, 2008
    I need codes for my RCR860 to connect with my Magnovox TV
  • Anonymous May 09, 2008
    i need the programming codes for a RCA RCR860 to to a Sanyo DVD Player
  • christy08 May 31, 2008
    i need codes for the remote to program it to another tv
  • robiken Jun 07, 2008
    what is code for sharp tv (aquos) to set verizon remote
  • drbagatha Aug 01, 2008
    i lost my manual for a RCR860 please help
  • rontylerdarw Feb 08, 2009
    not wpork
  • Anonymous Feb 19, 2009
    lost the code to rca tv remote control need help.
  • Cecelia Bowen Feb 22, 2009
    I have a rca rcu300 and I have been unsuccessful in programing the remote to my television. I do have the codes I tried 191 and 168 according the directions and neither seems to work. Help please I want to watch my movies.
  • Anonymous Mar 27, 2014
    cannot remove the channel list
    Problem Solver:
  • 8 Answers
I hope this helps some people. Please spread this info as I am. I don't usually bother sharing info like this but this was way beyond difficult.
This was WAY too hard to find. I can tell a lot of people have a problem finding any info on these darn remotes but I found finally found something.
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1134&p_created=1196116280&p_sid=QqnU6SVi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTE0JnBfcHJvZHM9MTU4JnBfY2F0cz0wJnBfcHY9MS4xNTgmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3NjZl9icmFuZD0mcF9wYWdlPTE*&p_li=&p_topview=1
The easiest thing is to do an auto code search.
To program a component using the Automatic Code Search method, perform the following steps:
1.Turn on the component you want the remote control to operate.
2. Press and release the component button that corresponds to the component you want the remote control to operate.
i. The illuminated ON-OFF button turns on and remains on.
3. Press and hold both the component and ON-OFF buttons.
i. The illuminated ON-OFF button turns off.
4. After the illuminated ON-OFF button turns back on, release both buttons.
i. The illuminated ON-OFF button remains on.
ii. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained.
5. Press and release the PLAY button.
6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
i. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
i. If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
ii. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
8. To save the new code, press and release the STOP button.
i. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
ii. If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Posted on Jan 16, 2008
  • 4 Answers
If you have an RCA Remote and need the codes, RCA has a website that you can use to look up the TV codes by model.
http://remotefinder.rca.com/default.aspx?site=rca
This should get you the codes
Posted on May 14, 2008
It worked just like you said
Posted on Feb 02, 2008
Http://157.254.235.130/public/RCR860_code_list.pdf
Do you know how to enter the codes? I dont remember nad need to know.
Thanks
Posted on Nov 10, 2007
  • 55 Answers
Doesn't it have an auto-scan mode? simply run it and click power every 2 seconds until it catches up.
Posted on Oct 23, 2007
Codes for sylvania lcd tv
with the tv on press tv button on remote then setup then enter one of the following codes 10171 or 11271 or 11314 the the tv should shut off if the right code is entered if it doesnt work then a setup code has not been set
Feb 08, 2008 | RCA RCR860 Remote Control
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Navilight 8 RcR860 remote
http://www.thomsonnetwork.com/EN/Public/InstructionBook/IBSearchResults?querytext=rcr860*&brands=RCA%2cGE%2cPROSCAN%2cRECOTON%2cSPIKEMASTER%2cAR%2cJENSEN%2cAMBICO%2cADVENT%2cUNBRANDED&doctypes=IB&categories=ACCESSORIES%2cAUDIO%2cCOMMUNICATION%2cDTVS%2cDVD%2cMULTIMEDIA%2cCOLOR_TV%2cVIDEO&firstdocnum=1
Nov 12, 2007 | P3 International TV Remote Control Clock...
RCA RCR860 Remote Control Logo
8,585 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
