Question about Motorola Mobility RAZR V3
Motorolla Razer V3i Keypad is not working
Hello, I have change my phone ring style to vibrate mode yesterday, after that my keypad stopped working... if i get a call i can accept it by making the phone wide open. But am not able to disconnect the call. While the call is active no other keys works too. I have connected the charger and the vibrate mode changes but still keypad dosnet work. When i disconnect the charger its going back to vibrate mode.. Can anyone help me.pls same problem.. no other solution???
  • fizzystriker Jun 02, 2009
    u sure?? vibration?? mayb possible. wat shud b done now?? any particular part 2 b replaced or any other information can u give abt it?
  • 421 Answers
Sir it is hardware problem because of vibration it damaged
Posted on Jun 02, 2009
SOURCE:
Vibration prblm
Go Settings => Ring Style = select Loud .. or Vibrate & Ring
Feb 17, 2010 | Motorola Mobility RAZR V3
How to change motorola v3i keypad - only the silver thing
you can change the Motorola keypad for that you need to contact the nearest Motorola service center for that
Oct 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
The keypad is not work.
Go to a technician and ask them to replace the connector or your keypad or the flex in your keypad. if those can't be done, try buying a new phone.
May 01, 2009 | Motorola Mobility RAZR V3i Cellular Phone
The best way I can recommend to fix this is to contact www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited.
It sounds like some moisture has gotten into the bottom of the phone and is shorting out the keys.
If you want to try it yourself, you need to replace the keypad flex
Jul 31, 2008 | Motorola Mobility RAZR V3
Motoprob
Hello there. yes changing the keypad will slove your problem without hassle. Hope i helped bye!
Jul 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Changing Ring Style
scroll down and it takes you straight to the ring styles and u can pick it straight from there x
May 20, 2008 | LG Shine KE970 Cellular Phone
Key pad sound
open ur phone menu first. then go to settings,open settings, then select ring styles,then select second option it can be as ??????detail.(???? = type of ring style u have selected,whther it is loud, soft, vibrating .vibe & ring or silent). just select second option,then scroll down and look for key tone type, select it and choose it as off, ur annoying keypad will silent. thanks best of luck.
Feb 24, 2008 | Motorola Mobility W375 Cellular Phone
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
114 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
