Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
I have the above mentioned washer/dryer and yesterday I was washing the dogs blanket and the washing machine stopped on the rinse/spin cycle (due to my 18 m/o pressing buttons as they do) and filled right up with water. Now the machine is detecting an upbalanced load and will not spin or pump out. Before I call out a repair man can anyone give any suggestions how I can get the water out of the machine without opening the door. Pls help xx I have a new Hotpoint washer drier but since moving home the washing machine willnot pump out the water on its wash cycle.
  • 142 Answers
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
2 Suggested Answers
sidthedog
  • 4 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Posted on Apr 20, 2008
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washer not completing the cycle
OK , try this , open washer and check out the DRAIN MOTOR PUMP located at the bottom on the side (its got like a little fan on it) , take it out and remove any debris & lint , it could be clogged , hope it helps , AJ
Jul 14, 2009 | Washing Machines
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Wash machine says E3
not sure where you can get a manual but sometimes blankets produce a lot of fluff while washing maybe the pump filter needs cleaning out the machine will not reach speed with too much water in it
Nov 11, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
979 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
