Question about Motorola Lands Phones
Motorola ME4052 dectphone.LCD display is not clear on both handse
The handsets were ok and still working perfect.The only problem is that the display characters on both handsets are almost gone.I mean some characters are displayed in half lenght or so.
SOURCE: Display on the cordless phone is distorted.
display reads
NAR FOES********
H4:107 LOUD C3
How do you remove it & get standard display
Posted on Apr 24, 2008
  • 201 Answers
SOURCE: Display is not working properly
There are 2+ possibilities.
If the LCD went out after a bad fall you may have cracked the display behind the scenes where you can't see it.
If the phone has EVER been exposed to water or high humidity.... (even 2 years ago) then corrosion in the connector for the LCD may have grown to the size to effect the operation of the LCD. If you feel comfortable taking the phone apart and removing the LCD you may see the corrosion... you can clean the LCD cable with isopropyl alcohol and possibly help the connector itself using a few drops of isopropyl and a tooth brush. If you do not visually see any corrosion then don't clean it... it would have to be visible to stop the LCD.
These LCDs can go bad on their own but it's rare.
Posted on Jun 12, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
  • 8 Answers
SOURCE: Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Posted on May 06, 2009
SOURCE: The display screen on the handset is blank
i just want to purchase another one or two????
Posted on Sep 08, 2009
Lost pixels
For lost pixels on the phone's LCD, it needs an LCD replacement. Most phone manufacturer, they just replace the phone itself instead of replacing the LCD on your wireless phone.
Aug 07, 2009 | Motorola Mobility 5.8GHz Digital Cordless...
My xda wont go passed the touchscreen set up I tryed resetting it but it wont work
The digitizer on top of the lcd display is most likely faulty, try a hard reset, if it doesn't solve the problem the digitizer would need to be replaced.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device.
2. Keep the two buttons pressed, and at the same time, use the
stylus to lightly press and hold the RESET button.
Jul 14, 2009 | O2 XDA Mini S Smartphone
User manual
There wasn't one on the Motorola Website, but I found one =>
http://www.sattrakt.com/proizvodi/_ME4052-UK_UG-120705.pdf
Download it fast before the link is removed.
Here's the Motorola Link for Cordless Phone Manuals =>
http://broadband.motorola.com/consumers/support/default.asp?supportSection=CordlessPhones
Dec 26, 2008 | Motorola Mobility MD4260-2 Twin Cordless...
How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
How do i transfer calls from handset to another line or to base
  1. Press the [Int] key located in the far lower right of the handset. The LCD will display "Transfer to:."
  2. Dial the number of the handset to which you are transferring the call. The LCD will show "Calling handset B." Handset B will ring, and the LCD will show "Handset A is calling."
  3. Press the "Talk" button or any of the numeric keys to answer.
  4. View the LCD. It should display "Intercom."
  5. Press "Off/Clear" on the first handset to transfer the call.
Nov 11, 2008 | Uniden Cordless Phone
Motorola format
go to MENU then SETTINGS then INITIAL SETUP then MASTER RESET (000000) OK.
Nov 10, 2008 | Motorola Mobility L6 Cellular Phone
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
Change my display name
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 06, 2008 | Panasonic KX-T7630 Corded Phone
Lands Phones Logo
54 people viewed this question
Top Motorola Lands Phones Experts
David Payne
David Payne
Pierre Curtis
Level 1 Expert
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
