Question about Canon PIXMA MP620 All-In-One InkJet Printer
Can't print business cards. Won't feed from rear tray.
I'm trying to print business cards on my canon mp620. I go into preferences and have it load from rear tray but it always goes back to feeding paper from the cassette. If I load the cassette with business card paper, it has trouble feeding it.
Thanks for any help.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
  • jleow21 Sep 19, 2010
    Thank you cubed !! - your solution Worked,
    it was driving me bonkers.
    Was going to return it on Monday and settle for a HP.
  • gt1997 Jul 17, 2011
    This solution worked for the iP4700 printer also. I was trying to print labels from the rear tray but the printer kept going to the cassette. The menus are slightly different but eventually you get to the same check box. Thanks.
Im trying to print an envelope from the rear tray and it continually says
i think encelopes are to thick.
try to set it in the midel of the tray
Nov 13, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I wanted to print a form from the internet The printer said The rear loader is empty I only use front loader and it is full I did not ask it to change to rear loader I want to use the front tray as I...
It could be several issues - although commonly when a printer moves from it's default tray it's due to a paper size conflict. The form you are trying to print may be a legal size form (8.5x14) or a a non US standard such as A3. Regardless, if the size is different than what's loaded in your main paper tray it will move to the secondary tray or to the MPF (Manual Paper Feed) tray looking for the appropriate size.
If you don't have the appropriate paper, you should be able to enter your printer properties and adjust the settings to scale the document to fit to page.
May 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Printer screen says that there is no paper when I just put some in the front feeder. I have a Canon MP620.
The MP620 also has a rear slot for smaller paper sizes. Did you perchance submit a print job for some
alternate paper size and the printer is expecting a rear load of paper?
Mar 22, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Loud clicking noise when attempting to print
Try removing the ink catridges and checking them for any damage like leaking ink. Then replace them and try to print. Also, make sure there is nothing stuck in the paper feeding tray.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Keep reading have no paper yet when I add paper it still say to load paper. Also there is a clunking sound that has developed lately.
PIXMA MP620 has 2-way paper feeding. Check your proper paper feeding. Rear feed or bottom cassette paper feed.
Jun 10, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Problem with printing business cards with HP Lasterjet 1320
If the cards are getting stuck in your printer, you first need to make sure the cards are rated for laserjet. If they are, then many times the cards don't like going through the curves of the machine. I would set them to feed from the tray on the front, which should be tray 1, and I would select them to eject out the rear of the printer, which you should be able to accomplish through the print drivers depending on what software you are using to print them.
Please let me know if you would like further assistance with this matter. Thank you.
Mar 23, 2009 | HP LaserJet 1320 Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Load mpf paper
    Your printer is set to default to the Main Paper Feeder, which is probably set for letter size paper. You must tell it to feed cards. On your Windows Desktop, left click mouse on START. left click on CONTROL PANEL, and left click on the PRINTERS icon. On the PRINTERS screen, RIGHT CLICK on your Dell printer icon. On the drop down menu, left click on PRINTING PREFERENCES. On the PRINTING PREFERENCES window, left click on the PAPER/QUALITY tab. Under TRAY SELECTION, choose the PAPER SOURCE where you want your business cards to feed from. Left click on APPLY button. Next, left click on the ADVANCED button. On the ADVANCED OPTIONS window, use the drop-down box next to PAPER SIZE to choose the paper size you want to feed. Press OK button. The PRINTING PREFERENCES window will now reappear. Left click APPLY, then OK buttons. After you have printed your cards, be sure to restore the printer defaults back to their original state, or the printer may jam because it must be programmed for the paper size being used. If you reload letter paper without resetting the paper size, the printer will think there is still card sized paper in the tray, and it will issue a jam or error code until the paper size is set properly.
    Jul 30, 2008 | Dell 3100cn Laser Printer
    Printing business cards
    Feed sheets through front manuel feed slot.
    base tray is mainly for up to 90grm paper,anything heavier
    can feed for a time but tends to fault.also try and clean the
    paper pick up rollers regularly.
    mongrelken.
    May 20, 2008 | Brother HL-2040 Laser Printer
    Canon PIXMA MP620 All-In-One InkJet Printer Logo
    1,642 people viewed this question
    old marine
    old marine
